problems with the 1-2 powershift
my car wont engage 2nd on a powershift. it doesnt grind but it just feels like there is a wall blocking the gear. i asked my mechanic and he doesnt know either. he says it might be the linkage but was unsure. he also said maybe its controlled by the ecu to not let it engage at redline. he specializes in hondas. at first i thought it was user error as i have ruled that out since i even had someone else try and fail. plus i tried so many times. i have been powershifting since i was 17 and im 30 now so i could say i was good at it. i have never had so much trouble until this car. (fg2). i cant tell the dealer 2nd wont engage on a redline powershift cuz then they wont fix it if somethings broke. what do you guys think the problem can be?
If you search the forums, you'll find this has been discussed multiple times. Don't try to powershift 2nd too much. Stay around 7500RPM on powershifts if you must PS 2nd. Otherwise, a nice, smooth shift into 2nd at redline will be the best you can hope for to be consistently on the shifts.
So wait, are you powershifting, as in, shifting without letting off the gas (which is what powershifting is...) or are you just trying to shift as fast as possible... Just trying to clarify. if you are REALLY trying to powershift (once again, No lift shift) then your an idiot, and you deserve the chunks of metal in your trans case, but if youre not, then just take it easy, shift slow enough to not grenade your trans, but quick enough to stay in VTAK.
#9 (permalink) | |
#10 (permalink) |
I don't know why there are so many idiots on here who think that powershifting isn't going to damage their transmissions. It may not happen right away, but eventually through wear and tear, it's gonna cause damage. And all of that for what?.....a few tenths of a second in the quarter mile.... ROTFL. If you want to go faster, buy a faster car or more performance mods. Don't beat the **** out of your daily driver for a few tenths of a second, unless of course your a total toolbag, then go ahead and powershift all day.
#13 (permalink) |
just my 2 cents...You have to decide if the possible destruction of your trans and cost to fix it is worth the time your saving down the track? Can you afford for your dd to break and be out of commission? Enjoy the car for what it is and dont abuse it. Slow your shifts. I have that same "wall" feeling in my car on the 1-2 shift. There was another member who suggested what he called a "light hand" method. Dont try to slam into second gear, try to feel it out with a light hand and you can feel when that "wall" goes away and you can then shift into second as fast as possible. Trying to shift before the "wall" goes away will just cause mis-shifts and eventually grinding. Trust me.
#15 (permalink) | |
#17 (permalink) |
look this guy can do it, then why cant we. did he do something to his car?
YouTube - Civic Si '07 TEST RUN 3 Last edited by kene79; 07-27-2009 at 12:30 AM. |
#18 (permalink) |
The reason the 1-2 is tough to power shift is due to the large change in ratio between 1 and 2 and the fact that the synchro (which is carbon on 2 and 3 I believe) isn't designed for such rapid engagement.
Honestly dude, power shifting is for losers. These kinds of post are what Honda laughs at when after reading another thread about guys complaining about problems with 3rd gear. Learn to shift with the clutch and a lift. Check out this vid: LINK Fast forward to 2:50, the red Civic that passes, you can hear the shifts, thats clutch and lift. No respectable driver power shifts. Unfortunately I don't have links to in car from that or the other (#41) Civic, luckily they're plenty loud enough that in car from other cars illustrates my point. Power shifting is for wankers... don't do it. If you want to no-lift-shift... get an automatic. -SWRT |
#19 (permalink) | |
I/E/RH NO REFLASH
![]() ![]() And on a different car: SOHC all motor hatch.. ![]() -udumkid Last edited by udumkid; 07-27-2009 at 12:33 AM. |
#20 (permalink) |
^ ok you shift really good. thats how i have always shifted in my other cars, but my si is more complicated. say i practice some more and keep hitting that 2nd gear wall whats the worst that can happen. will i break something? does this kind of car require learning to powershift the 1-2 all over again? i mean i can powershift 3,4,5 no problem but 2nd is where i have problems. did your car always let you ps into 2nd or did you have the same problems i have now and you had to practice some more. i need all the help i can get.
| how to powershift | swiader | Autocross & Sanctioned Drag Racing | 81 | 08-16-2009 07:37 AM |
| H.I.D problems | fatdsm | Lighting, H.I.D.'s, & Neon | 20 | 02-21-2009 01:38 AM |
| Powershift | Asif22 | Autocross & Sanctioned Drag Racing | 25 | 09-03-2008 05:57 PM |
| How many powershift at the Track? | slvrSI2.0 | Autocross & Sanctioned Drag Racing | 45 | 05-31-2008 09:28 PM |
| help, little problems. | joohanie | Mechanical Problems & Technical Chat | 6 | 05-09-2008 05:47 PM |
