Q on IAT and TPS in ScanGauge II - 8th Generation Honda Civic Forum
Old 07-24-2009, 02:45 PM   #1 (permalink)
Keith P's Avatar
Question Q on IAT and TPS in ScanGauge II
I've been using my ScanGauge II for about 2 months now. I love seeing all the parameters and tracking my MPG.
Two questions came up.
1. While it is 68-75°F outside, my IAT is around 110-135°F. It drop to the high 90s when driving. Is this normal? The temps seem high to me. Could a clogged air filter cause this?
2. When I have the car off the TPS reads 17. When started it reads 14. When at WOT it reads around 78. Shouldn't this be reading from 0-100?!? Is this normal?
Thanks all!
Keith P is offline
Old 07-24-2009, 03:12 PM   #2 (permalink)
Robert
I'm not sure about this car specifically, but WOT does not mean WOT. A lot like a governor, this keeps some people in check and keeps them from putting too much stress on the motor.
Those temps sound about about right on a stock intake.
rhobere is offline   Reply With Quote
Old 07-24-2009, 04:28 PM   #3 (permalink)
kingcuongo's Avatar
from what i remember, with my stock intake, i was a bout +20 ambient temp when moving.
i don't use the TPS function
kingcuongo is offline   Reply With Quote
Old 07-24-2009, 05:17 PM   #4 (permalink)
raybyduhbay's Avatar
Ray
TPS cant be 0 or else there will be no air going in.
and on my car I know when i floor it it goes up to 99
my car idles at 14
raybyduhbay is offline   Reply With Quote
Old 07-24-2009, 06:03 PM   #5 (permalink)
kingcuongo's Avatar
my car idles at 14
then that just means you need to floor the car harder OP lol
Old 07-24-2009, 06:11 PM   #6 (permalink)
Robert
OP, What trim level is your car? manual or automatic? If its an auto its possible that it prevents you from opening the throttle all the way at low RPM to prevent it from bogging down.
Old 07-24-2009, 07:02 PM   #7 (permalink)
Keith P's Avatar
It's a 6 Speed Si.
Keith P is offline   Reply With Quote
Scangauge II and Si Trigon Civic SI 8 10-23-2008 01:28 PM
Post your thoughts about the ScanGauge II 8thgenSilverEx Garage 9 06-09-2008 11:59 AM
