Old 07-04-2009, 04:03 AM   #1 (permalink)
cambodianricer's Avatar
Jessica
Possible problem with top hat?
So right, i was adjusting my height on my Pro-S, I noticed that the spring was stuck up on the shock. So I pulled the spring down and all of these metal balls come out!!! I have no idea wtf it is... So what should I do?
Btw, this is on my front right side.
Metal Balls:
I think its #14 Bearing back
please help meeeeee!
cambodianricer is offline   Reply With Quote
Old 07-04-2009, 04:04 AM   #2 (permalink)
''CA'' All day.
Zeuceone's Avatar
hahahah
Originally Posted by Zeuceone View Post
For a good time call 909 418 8773
Old 07-04-2009, 04:05 AM   #3 (permalink)
Jessica
thanks for the help
Old 07-04-2009, 04:06 AM   #4 (permalink)
#1 Post Whore
07mugencivic's Avatar
ToE kNeE
you have too many balls
Originally Posted by 0720Steve View Post
we should rename : beer: to :tony:
Old 07-04-2009, 04:06 AM   #5 (permalink)
''CA'' All day.
Zeuceone's Avatar
why would you pull on it? the spring is held by the top hat. remove the strut and put all the bearings back in it.
Old 07-04-2009, 04:07 AM   #6 (permalink)
Jessica
so what if i cant find all of the balls?
Old 07-04-2009, 04:08 AM   #7 (permalink)
Siem Reap's Avatar
Robert
Good luck man, definitely invest in a magnet, you don't want to lose those. I dropped my car on skunk2's and those damn little balls went everywhere.
Siem Reap is offline   Reply With Quote
Old 07-04-2009, 04:09 AM   #8 (permalink)
''CA'' All day.
Zeuceone's Avatar
should still work if its only a couple.
Old 07-04-2009, 04:12 AM   #9 (permalink)
Jessica
so what was your solution?
so just take apart the shock and stuff and try to put the balls back into their place in the bearing thingy?
Old 07-04-2009, 04:17 AM   #10 (permalink)
Siem Reap's Avatar
Robert
Pull the shock/strut tower out, compress the spring, remove the tophat and VERY CAREFULLY remove the cover for the ball bearings and place them back in. I can't stress enough the VERY CAREFULLY part. If you aren't, those little fawkers will go everywhere.
Old 07-04-2009, 04:19 AM   #11 (permalink)
Jessica
im gonna try that tomm! i really hope everything if fine...
but what if im missing a couple of the balls?
Old 07-04-2009, 04:20 AM   #12 (permalink)
Siem Reap's Avatar
Robert
Looks like the OP is holding quite a few. I lucked out and was able to put them all back in. Definitely would recommend putting as many as you can back in. No more than 1 or 2 missing, and definitely if they are missing in a row. Like this...
Zero's = ball bearings; periods = missing bearings
0000.....000 <-- probably bad
0.00.000.00.0.000. <-- probably ok...
Just because that pressure will be more evened out in the second example as opposed to the first.
Old 07-04-2009, 04:22 AM   #13 (permalink)
Siem Reap's Avatar
Robert
Also, get an OEM MacPherson spring compressor. Those things work miracles. You don't want your top hat to explode off the top of the shock/strut. Very dangerous.
You can pick up the compressor at autozone for like 40 bucks. I think it's worth it, because to rent one, it's like 20, and if you ever want to go back to OEM or switch out the springs again, it's nice to have.
Plus you can just rent it out to your buds
Old 07-04-2009, 04:24 AM   #14 (permalink)
Jessica
thanks but i dont think i need a spring compressor... the spring has LOTS of free play when there is no load on it... i think this is normal...
i hope i can find the rest of the balls... or is it possible for me to go down to autozone or something and buy replacement balls of the same size?
Old 07-04-2009, 04:26 AM   #15 (permalink)
Jessica
and how many balls should there be??
Old 07-04-2009, 04:27 AM   #16 (permalink)
''CA'' All day.
Zeuceone's Avatar
enough to fill all the holes.
Old 07-04-2009, 04:29 AM   #17 (permalink)
Jessica
i know i know. im super pissed/ paranoid right now....
Old 07-04-2009, 04:55 AM   #18 (permalink)
Siem Reap's Avatar
Robert
If you're only missing like 1 or 2 I wouldn't worry. Couple of people I know lost a couple and they haven't had any issues.
Old 07-04-2009, 04:56 AM   #19 (permalink)
Jessica
yea, ive been searching on the forum, people say there should be about 30 of them... so i have 12 or so.. i hope the rest is there
Old 07-04-2009, 04:47 PM   #20 (permalink)
Jessica
alright, i took out the coils today and i saw that i was missing a bunch of metal balls. most of them have fell out and stuck to the rubber parts. anyways, i pull all of them back in and at the end, i was missing 3 balls. I compressed the top hat just to make sure it would stay and then i reinstalled everything. hopefully it'll be fine. now i know not to pull on the spring.... such a n00b move
Top 100 Video Games (Your Top 10) PaulShoe Video Gaming 74 05-26-2009 08:35 PM
Top 5 Wuddup Video Gaming 10 10-08-2008 02:01 PM
Civic Si: MPH Top/Rev Bottom or....Rev Top/MPH Bottom? Crucifer Civic SI 28 08-24-2008 07:15 PM
When to top up oil? semaj550 Civic SI 17 01-27-2008 10:09 AM
Top 20 Top-Selling Vehicles For June 2007 webby Honda Industry News 6 07-09-2007 01:42 AM
