transmission problem =( - 8th Generation Honda Civic Forum
Old 07-03-2009, 08:14 PM   #1 (permalink)
Unhappy transmission problem =(
basically my transmission is takin a poop on me.. its really hard to get it in gear especially first gear.. when im at a dead stop and try to put it in first it doesnt engage, but the car slowly moves then seconds later first finally engages and when changing gears it doesnt transition smoothly it takes like a second to engage, and worst of all if im at a stop light with the car still in first gear it the car would jerk and shut off. Another problem, i have no reverse! it grinds every time i try to put it in reverse and when i do manage to get it in reverse my car jerks violently and makes this loud ass knocking noise coming from the bottom and then stalls out. My buddy told me its the flywheel can anyone on here confirm that or is it something much worse? PLEASE HELP
BlkFA5 is offline
Old 07-04-2009, 02:29 PM   #2 (permalink)
Andrew
sounds like a clutch issue
ajb7895 is offline   Reply With Quote
Old 07-04-2009, 05:21 PM   #3 (permalink)
David1017's Avatar
David
how many miles does your car have? and when was the last time you changed your transmission fluid? I saw some other people I think on this forum about how their gears don't go in at all.
David1017 is offline   Reply With Quote
Old 07-05-2009, 07:39 PM   #4 (permalink)
my car has about 35k miles.... i cant recollect when was the last time i changed out my tranny fluid
BlkFA5 is offline   Reply With Quote
Old 07-05-2009, 10:42 PM   #5 (permalink)
DumpTruck's Avatar
I'm voting clutch issue as well, but it would be very weird for the clutch to be bad at 35k. if the engine is not running, is it easy to move the shifter thru the gears?
Go ahead and change the trans fluid regardless, it can't do anything but help.
Last edited by DumpTruck; 07-05-2009 at 10:43 PM. Reason: can't type worth crap on a laptop
DumpTruck is offline   Reply With Quote
Old 07-07-2009, 04:59 PM   #6 (permalink)
yeahhh its like normal when the engine is off...
Old 07-07-2009, 04:59 PM   #7 (permalink)
quickfit's Avatar
Resident asshat
bring it to the dealer?
quickfit is offline   Reply With Quote
Old 07-07-2009, 05:12 PM   #8 (permalink)
Eric.'s Avatar
Eric
You should take it to a dealer for diagnosis at least. If its the clutch you'll be paying for it either way, but if its something else and you're just tearing it up worse they aren't going to be real happy to cover it either.
Eric. is offline   Reply With Quote
transmission problem? need4speed423 Mechanical Problems & Technical Chat 6 07-13-2008 01:16 AM
Si Transmission Problem Makes Consumerist BigRed55 Civic SI 0 03-14-2008 07:23 PM
transmission problem spammy123 Mechanical Problems & Technical Chat 4 11-28-2007 08:43 PM
transmission problem? marksi07 Mechanical Problems & Technical Chat 4 11-01-2007 08:39 PM
Transmission problem ryryninja Mechanical Problems & Technical Chat 8 02-27-2007 02:37 AM
