Screeching Noise Coming From The Rear Passenger Wheel - 8th Generation Honda Civic Forum
Old 07-01-2009, 09:14 PM   #1 (permalink)
Scrodums
I noticed this morning that I had a noise coming from the rear passenger wheel. The noise seems to happen at shorter intervals when you move faster. In other words, it gets progressively worse the faster you drive. Also, the noise will go away under braking. I would describe the noise you hear when knives get sharpened.
What do you think it could be, a rock stuck in the dust shield or ...? I'm hoping it isn't a bad wheel bearing. This happened to my girlfriend on her GTI and it was just a rock that was stuck. Otherwise, I will have to take the wheel off some time tomorrow and turn it slowly to see if there's anything I can pick up on. Also, the pads have plenty of life in the rear.
Yodums is offline
Old 07-02-2009, 10:19 AM   #2 (permalink)
boltuprite's Avatar
Gary
wheel bearing?
boltuprite is offline   Reply With Quote
screeching noise from right rear. jethroooo Suspension and Brakes 20 03-29-2009 12:01 AM
screeching sound coming from rear left Haaska Mechanical Problems & Technical Chat 4 03-05-2009 12:39 PM
sounds coming from my passenger rear wheel fynestpi Mechanical Problems & Technical Chat 1 02-04-2009 08:59 AM
wierd screeching noise coming from my car. need your input. Epileptic California South 21 12-10-2008 08:42 PM
Splish Splash Noise Coming From Passenger Side donjuanle Mechanical Problems & Technical Chat 7 05-29-2008 05:22 PM
