Possible hydrolocked or something else not sure???? - 8th Generation Honda Civic Forum
Old 07-01-2009, 02:20 PM   #1 (permalink)
jdmfg208's Avatar
Hector Lavalle
Well its been raing all night long and all this morning well I had to take the wifey to work and I was going thru my normal route when I see a puddle that covers both sides of the street but it looked low enough that I should have made it thru.... Well half way thru the car starts slowing down and shuddering and then it shuts off so I pull over and try to turn it on. I hear it trying but nuttin so after maybe a minute I try again n it turns on but starts shuddring again n then it shuts off so I turn it back on n it does so I limp it over to a parking lot and I just let it sit there (still on) for a minute.
I rev it a few times in neutral and everything sounds normal so I put it in gear to get out and as I am lifting my foot from the clutch so it can get to the catching point it starts to feel wierd not like it use to be yesterday but its moving forward.
Then at stop lights it starts idling wierd as well, it would b around 600rpm then jump up to 1000rpm n then drop back down to normal.
Now after I drop her off I deciede to accelerate faster then my normal way to see if acts funny so by then the wierd idling is gone and the car is driving normally but not really sure
also info on my car is its an 08 civic si has modified stock intake throttle body spacer k&n drop in filter and dropped on sportlines.
Oil life is also at 40% but I am going to change today just to be safe.
Any tips on what I can do to make sure my motor hasn't hydrolocked? Or what else could have happened? thanks
jdmfg208 is offline
Old 07-01-2009, 02:27 PM   #2 (permalink)
Ed
When changing your oil, it should give you some indication if you have water in your block.
ImAllStock is offline   Reply With Quote
Old 07-01-2009, 02:30 PM   #3 (permalink)
iamchris's Avatar
I don't think it was hydro lock. If you drove it after you got water in the engine your connecting rod would bend and you would definently notice something wrong.
Actually I stand corrected. Thats only if you got a lot into the engine. A small amount could possible cause the things you were talking about it. I'd get a mechanic to look at it asap.
iamchris is offline   Reply With Quote
Old 07-01-2009, 02:30 PM   #4 (permalink)
djphoenix18's Avatar
if you hydrolocked your engine, and you luckily did not blow the motor up ...
you want to do this:
#1. do not drive the car with the water in the oil
#2. drain the oil and water out of it immediately.
#3. change the filter and oil with new oil and filter.
#4. idle the engine for 5 minutes.
#5. drain the oil and filter again.
#6. put a new oil filter and add new oil.
Your lucky your motor even turned on at all.
djphoenix18 is offline   Reply With Quote
Old 07-01-2009, 02:34 PM   #5 (permalink)
Si-Onara
JEA86's Avatar
Jeremy
^^ agreed, it could try and compress water that could have possibly been sucked up!
JEA86 is offline   Reply With Quote
Old 07-01-2009, 02:35 PM   #6 (permalink)
jdmfg208's Avatar
Hector Lavalle
What should I look for? Never had this problem with any of my other cars so this is first. And what if there is water in my block what should I do then? If I have water in the block shouldn't the car be running all messed up cause right now the car is running normal should I change out my spark plugs?
jdmfg208 is offline   Reply With Quote
Old 07-01-2009, 02:36 PM   #7 (permalink)
Thats why i always play it safe when it comes to high water around the city.
Id rather sit and wait it out than have to go begging to the dealer to replace my engine.
Old 07-01-2009, 02:37 PM   #8 (permalink)
jdmfg208's Avatar
Hector Lavalle
Damn I am stuck at work so I need to drive it back home to do the oil change and stuff. so ihave to buy about 8-10 quarts of oil and 2 oil filters?
Old 07-01-2009, 02:38 PM   #9 (permalink)
Flooding is bad people. Mmmmkay
Old 07-01-2009, 02:39 PM   #10 (permalink)
jdmfg208's Avatar
Hector Lavalle
Yea but me and the wifey had to go to work to make the money if we didnt have to work then I would have just stayed home
Old 07-01-2009, 02:40 PM   #11 (permalink)
I would just drive and hope for the best, one of the first things you would notice is rough running and bad gas milage. If anything does'nt sound right ..take it in.
And once get an oil change as soon as possible. That is where the water ends up.
Old 07-01-2009, 02:41 PM   #12 (permalink)
jdmfg208's Avatar
Hector Lavalle
Wow!!!!!!!!!! **** well I check everything out!!!
Old 07-01-2009, 02:42 PM   #13 (permalink)
Here is a good link to what you may have to do:
hit a puddle, possible hydrolock? - Honda Civic Forum
Old 07-01-2009, 02:43 PM   #14 (permalink)
If your car is running after the hydrolock event, it seems like you avoided catastrophe.
Get your oil changed ASAP, and keep a close eye on how your car is acting and go from there.
Old 07-01-2009, 02:43 PM   #15 (permalink)
jdmfg208's Avatar
Hector Lavalle
Yea I am going to change the oil as soon as I get home I'm going to that procedure that you wrote will it be fine to run cheap oil for those five minutes then switch to m1 syn. and filter for the final flush n fill?
Old 07-01-2009, 02:44 PM   #16 (permalink)
^ Sounds like a plan, and see how the car runs afterwards.
Old 07-01-2009, 02:45 PM   #17 (permalink)
And hey i understand man!! G/L with it...
Old 07-01-2009, 03:05 PM   #18 (permalink)
jdmfg208's Avatar
Hector Lavalle
Yea thanks man you have been really helpful also I called a few places to see what oil change specials they have and one place has it regular oil for 14.99 plus filter so I was gonna use that for the first flush and fill and then run the car on that for the five minutes then flush that out and fill the car back up with full synthetic and a new filter is that kewl?
Should I check the spark plugs? or just go ahead and replace them as well? I am also going to buy a compression tester so I can test it this weekend
Old 07-01-2009, 03:13 PM   #19 (permalink)
^ At this point it cant hurt to dot the i's and cross the t's to make sure all is well.
Old 07-01-2009, 03:27 PM   #20 (permalink)
jdmfg208's Avatar
Hector Lavalle
ok then well when I am getting the oil from the store I'll check how much the plugs are what brand do you recommend?
hydrolocked 350z Wreckless06si Water Cooler 15 12-14-2011 06:49 PM
My Si was just hydrolocked and.... edrhee83 Mechanical Problems & Technical Chat 45 02-14-2010 06:15 PM
car got hydrolocked..... forcefanajd Bolt-Ons And All-Motor 56 02-01-2009 11:58 PM
Hydrolocked my Si. Thinking motor swap loves to speed Mechanical Problems & Technical Chat 109 12-16-2008 04:08 PM
Hydrolocked? silkyPimP Mechanical Problems & Technical Chat 26 10-23-2007 09:06 PM
