Engine Ticking LOUDLY - 8th Generation Honda Civic Forum
Old 07-01-2009, 10:13 AM   #1 (permalink)
Tricia07CivicSi's Avatar
Tricia
Unhappy Engine Ticking LOUDLY
So Monday night I noticed my car sounded like a diesel and was ticking loudly, then it never went away, when I drive it gets louder, u can hear it from down the road, sounds like I have a bent valve, but I dont understand how bc I never drive my car hard....Im so worried, I dont know what the hell is wrong but my car sounds like its gonna blow up
Tricia07CivicSi is offline
Old 07-01-2009, 10:21 AM   #2 (permalink)
gizyuluu's Avatar
is your car still under warranty?
gizyuluu is offline   Reply With Quote
Old 07-01-2009, 10:24 AM   #3 (permalink)
Chubs's Avatar
Token G35 Guy
si or not?
Chubs is offline   Reply With Quote
Old 07-01-2009, 10:26 AM   #4 (permalink)
cderalow's Avatar
Chris
Si or not, it sounds like you need a valve adjustment
Old 07-01-2009, 10:28 AM   #5 (permalink)
Chubs's Avatar
Token G35 Guy
naw, there's some things that make the Si sound like a loud ticking. My water pump bearings were bad causing that sound. There's also another ticking noise I have now and that would be my tensioner pulley's bearings going bad. FML.
Old 07-01-2009, 10:28 AM   #6 (permalink)
Tricia
yes its a 07 Si sedan with 40 k on it, it should not have gone bad so soon
Tricia07CivicSi is offline   Reply With Quote
Old 07-01-2009, 10:29 AM   #7 (permalink)
Tricia
it gets louder and worse as the rpms go up and it goes slower at idle
Old 07-01-2009, 10:29 AM   #8 (permalink)
Chubs's Avatar
Token G35 Guy
I had my waterpump replaced at 28k.
idk, do u have an extended warranty? take that bish back.
Old 07-01-2009, 10:31 AM   #9 (permalink)
Tricia
its still covered under the powertrain warranty which is 5yrs/60,000
Old 07-01-2009, 10:32 AM   #10 (permalink)
cderalow's Avatar
Chris
this dictates that it's either the valves, or a bearing on a pulley attached to the serpentine belt.
take it in.
I've got money on valve adjustment.
Old 07-01-2009, 10:38 AM   #11 (permalink)
Tricia
take it in.
really? what would cause it to go out of adjustment? the only way I can explain the noise is, back in the day when i used to put soda cans on the back tire of a bike and it made that noise, thats the exact noise my car is making.
Old 07-01-2009, 10:42 AM   #12 (permalink)
Chubs's Avatar
Token G35 Guy
i've got money on valve adjustment too. Mine wasnt as near that loud...
Idk, newer honda engines are built crappily. Like my throw out bearing is going bad...it's been going bad since 38k. It keep gettin louder and louder.
Old 07-01-2009, 10:43 AM   #13 (permalink)
bouncer07's Avatar
Gnehp Gnoix
Valve adjustment , take it in.
bouncer07 is offline   Reply With Quote
Old 07-01-2009, 10:56 AM   #14 (permalink)
Tricia
I have to take my exhaust off though or they will try and blame it on my mods, honda service shops ftl
Old 07-01-2009, 10:58 AM   #15 (permalink)
Chubs's Avatar
Token G35 Guy
tru that. I gotta take off my TBS before I take it in...I'm also thinking about taking off my HFP suspension before I take it in and putting stock stuff on it.
FML.
Old 07-01-2009, 10:59 AM   #16 (permalink)
E-Tunez Tuner
Dan0974's Avatar
Dan
take it in.
If it's a valve adj wouldn't the knock sensor pick it up and through a cel?
Dan0974 is offline   Reply With Quote
Old 07-01-2009, 10:59 AM   #17 (permalink)
E-Tunez Tuner
Dan0974's Avatar
Dan
And if all you have is exhaust, they can't blame the engine ticking on exhaust
Old 07-01-2009, 11:02 AM   #18 (permalink)
Chubs's Avatar
Token G35 Guy
actually they can...they can say "it's the exhaust valve that needs adjusting due to improper backpressure".
Honda is shady dude.
Old 07-01-2009, 11:04 AM   #19 (permalink)
E-Tunez Tuner
Dan0974's Avatar
Dan
Didn't think about that
Old 07-01-2009, 11:07 AM   #20 (permalink)
Chubs's Avatar
Token G35 Guy
it's all good. Honda said they will void warranty on the engine if an exhaust has been put on from the header back to the axle. They said they would keep the warranty if the exhaust was only a axle back. I've asked all of these questions hence why my car is remaining stock.
Ticking sound in the engine! please help Gravity0002 Mechanical Problems & Technical Chat 26 03-31-2009 08:58 AM
engine ticking Togish1 Mechanical Problems & Technical Chat 2 10-13-2008 03:17 PM
Slight ticking sound coming from the engine? joebelin Mechanical Problems & Technical Chat 19 01-22-2008 01:47 PM
Ticking from engine, possible fix. yearight Mechanical Problems & Technical Chat 43 03-12-2007 11:34 AM
engine ticking edciv Mechanical Problems & Technical Chat 5 10-31-2006 03:10 PM
