Old 06-29-2009, 10:03 PM   #1 (permalink)
Jackson
bad thermostat symptoms?
could a faulty thermostat cause both radiator fans not to engage?
silver8thcivicr18 is offline   Reply With Quote
Old 06-29-2009, 10:26 PM   #2 (permalink)
The Power of Dreams's Avatar
My Cool
One is a condenser fan. One is a radiator fan.
With the AC on, do any of the fans operate? Both should.
The Power of Dreams is offline   Reply With Quote
Old 06-29-2009, 10:38 PM   #3 (permalink)
Jackson
yes both of them come on
Old 06-29-2009, 11:59 PM   #4 (permalink)
In my experience, the thermostat is purely mechanical. It functions to restrain the liquid coolant to your engine when the coolant is cold (like in the mornings) to heat up the coolant to operating temperature quicker. After a certain temperature it automatically opens to allow full circulation though your heater core. That is why it takes a few minutes for your heat to come on during cold mornings. Your fan should come on when the coolant is too hot. If your thermostat is stuck in the blocked position, it could overheat quicker, it will also completely disable your heater from working. So, start up your car and when it warms up, check if the heater works, if the answer is no, you may well have a broken thermostat.
habitat is offline   Reply With Quote
Old 06-30-2009, 12:09 AM   #5 (permalink)
My Cool
When the thermostat opens, it allows full circulation to the radiator, not the heater core. It takes a while for heat to be produced by the heater core because the coolant is still relatively cold and has not been heated sufficiently by the engine.
Restriction of coolant through the heater core is a function of the heater valve. Some Hondas have one; others do not. With those that do not, the air mix control door is used to allow heated air into the cabin, or to preclude its entrance, depending on the driver's desire.
Old 06-30-2009, 12:13 AM   #6 (permalink)
Ah yes that also makes sense, well same concept i suppose. If the thermostat is in an always on position, it would always pass through the radiator causing your morning startup(and heater) to take longer than normal, correct?
Old 06-30-2009, 12:15 AM   #7 (permalink)
My Cool
Ah yes that also makes sense, well same concept i suppose. If the thermostat is in an always on [open] position, it would always pass through the radiator causing your morning startup(and heater) to take longer than normal, correct?
Yup, yup.
thermostat Overdosedvtec Mechanical Problems & Technical Chat 8 06-25-2009 01:15 PM
Summary of 3rd Gear Problem Symptoms icen Civic SI 2 03-01-2008 04:23 AM
Thermostat Issue? phila Mechanical Problems & Technical Chat 8 07-26-2007 01:24 PM
06+ Thermostat Temp k20z3civic Civic SI 1 05-22-2007 10:49 AM
Senator hospitalized with stroke-like symptoms 2fast4u2 Water Cooler 2 12-13-2006 10:13 PM
