Interior Dash Lights WONT light up!!!
hey i have a 2007 civic lx with 30,000 miles on it
im having a problem with the interior dash lights....the radio part wont light up. mine is the stock deck one...i checked fuse #14 and its not blown....the ac and all the other lights come on, just not the ones on the radio....heres a pic Attachment 21984 does any one know what to do? i recently did some work (put in foglights, and a few led's in the interior..but only used the radio fuse...everything was working fine..after like 2 weeks..this happend) Last edited by BlackCivic07; 07-06-2009 at 11:16 AM. |
Ray
that happened to me too when after i installed the fog lights. My dash lights didnt turn on. I thought I blew a fuse at first untill i started to drive around and on some bumps my interrior lights would turn on flash real fast. That lead me to discover that the harness was loose. Just make sure the whole harness is tight and make sure all other plugs are tight too. =]
The foglights are universal...there hooked up to the battery and a switch on the inside, I didn't touch the fuse box to install thoes. all I did was use that one bolt near it for a ground so they couldn't have done anything. Not all the interior lights are out, just the ones on the radio...the ac lights work fine....Does any one know if there's a specific plug just for the radio lights that might be loose?
only radio knob and button dash light out
I have almost exactly the same problem except i haven't add or changed anything on my 2007 civic ex sedan. all other dash lights work, the time on the radio light works... just the control knobs and button light is out. Does anybody know how to fix that one issue?
how many miles are on your car?
yea...i dont think any of my mods could have done anything...i installed everything almost a month ago, and then last night, out of nowhere, i notice that the radio lights dont work (the control knobs and the button lights) do you think this will be covered under warranty?? let me know if you take your car to the dealer... |
I've got 60k miles on my car... so as far as warranty goes, I'm SOL. So I dunno. I looked up some stuff online and it looks like the lights are little LED lights on circuit boards or something... it doesn't appear to be as easy as a bulb to screw in... its kinda a drag.
im gona stop by the dealer tomorrow and see what they say...hopefully it isnt anything major...i searched here on 8thcivic, and i saw a guy with a similar problem, he said the dealer changed the entire radio unit...u should just go to the dealer though and see what they say,,,
#16 (permalink) |
they call mr dru
they were like its not fuse, obvious cus i checked, they said they didnt no what the problem was becus everything was working but the radio lights arent and that for a charge they will take a look at it, but the dealer overcharges for simple stuff so i was gonna find some one else to check it out or if not ill try to figure it
| That little red light up by the interior lights? | 07k20z3ftw | Civic SI | 48 | 11-30-2009 05:03 PM |
| 06 EX sedan; fog light indicator light in dash? | 06NaviEX | Lighting, H.I.D.'s, & Neon | 1 | 01-30-2008 08:15 PM |
| 07 SI interior/dash lights | 07si&06wrx | Lighting, H.I.D.'s, & Neon | 12 | 06-05-2007 08:08 PM |
| Ebay Fog lights, no light on dash | jpv027 | Mechanical Problems & Technical Chat | 4 | 01-05-2007 02:21 AM |
| 2006 Fog Lights and Interior Accent lights | acoloreo | Garage | 8 | 07-04-2006 01:14 AM |
