ATTN: si owners. please check the back of your engine near your header/heat sheild. - 8th Generation Honda Civic Forum
Old 06-28-2009, 08:15 PM   #1 (permalink)
jokka's Avatar
so i decided to rub my fingers around that area to check for any leaks and VOILA. got myself a nice smudge of black gunk all around the gasket area.
it was funny how the stealership said that they couldnt find the source of the leak. going to show them these pictures.
jokka is offline
Old 06-28-2009, 08:18 PM   #2 (permalink)
jokka's Avatar
i went to the dealership like 10k miles ago and the tech told me that he replaced the head gasket. looks like he made the situation worse.
jokka is offline   Reply With Quote
Old 06-28-2009, 08:18 PM   #3 (permalink)
0720Steve's Avatar
i have it there too
0720Steve is offline   Reply With Quote
Old 06-28-2009, 08:19 PM   #4 (permalink)
lovecheese's Avatar
James
I have it too, so does my other buddy.
Old 06-28-2009, 08:20 PM   #5 (permalink)
jokka's Avatar
so you guys are just letting it leak and filling up the engine when oil levels get low ?
Old 06-28-2009, 08:20 PM   #6 (permalink)
pineapple's Avatar
Kauinui
How in the piss you get way the hell back there LOL
pineapple is offline   Reply With Quote
Old 06-28-2009, 08:21 PM   #7 (permalink)
jokka's Avatar
my point and shoot camera + alittle ingenuity = l33t pictures.
Old 06-28-2009, 08:21 PM   #8 (permalink)
lovecheese's Avatar
James
Im going to the dealer monday.
Old 06-28-2009, 08:25 PM   #9 (permalink)
jokka's Avatar
i wish i knew this sooner. if you go in there without knowing the source they'll most likely **** you over by playing it off
Old 06-28-2009, 08:25 PM   #10 (permalink)
pineapple's Avatar
Kauinui
I need to do the same to my two Si's and see if mine is leaking as well.
Old 06-28-2009, 08:27 PM   #11 (permalink)
midnitesi's Avatar
james
had it on my fg2....its not a leak leak...i was told is residuall for oil that may leak out during break in
midnitesi is offline   Reply With Quote
Old 06-28-2009, 08:27 PM   #12 (permalink)
jokka's Avatar
just reach back and you be able to reach where the gasket is. if you get chunky/black oil on your fingers, call the dealership.
Old 06-28-2009, 08:28 PM   #13 (permalink)
jokka's Avatar
30k = way past break in.
Old 06-28-2009, 08:29 PM   #14 (permalink)
midnitesi's Avatar
james
its residuall...clean it and check in 1000 miles
Old 06-28-2009, 08:30 PM   #15 (permalink)
jokka's Avatar
could the residue leak downwards to the bottom ? b/c i noticed a patch of blackness down there as well.
Old 06-28-2009, 08:32 PM   #16 (permalink)
midnitesi's Avatar
james
yes....like i said clean it and check in 1k miles....if it comes back then its a leak....clean with break cleaner
Old 06-28-2009, 08:55 PM   #17 (permalink)
jrfiji20si's Avatar
jordan
When I took my car in for the third gear fix they called me half way through reinstalling the trans and said my valve cover was leaking and said they would replace the gasket no charge. Haven't had a leak since 3 rd done at 20know have 27500 on it and no more leaks. I wonder if this is a normal problem on si's
jrfiji20si is offline   Reply With Quote
Old 06-28-2009, 09:01 PM   #18 (permalink)
redvtech07's Avatar
I didn't notice anything when I put my header on there
redvtech07 is offline   Reply With Quote
Old 06-28-2009, 09:07 PM   #19 (permalink)
it just needs a valve cover gasket trust me we get these all the time k20s produce to much heat and keep track of ur oil level after awhile it burns like a B series
redmugensi is offline   Reply With Quote
Old 06-28-2009, 09:18 PM   #20 (permalink)
Admin Ninja
obert's Avatar
obert
I have it a little bit not any were close to what you have. I think it will just replace the gasket when I get my JDM vavlve cover !
My Civic Feature On NW-Built
Get rid of Check Engine w/ Race Header? Help! V-Tekken Mechanical Problems & Technical Chat 5 07-18-2008 05:55 PM
RACE HEADER vs CHECK ENGINE GreyK20z Header Discussion 11 11-09-2007 09:40 PM
Heat sheild for DCRH Freq18hz Bolt-Ons And All-Motor 2 07-14-2007 10:22 AM
Heat wrap/sheild needed? reaper702 Bolt-Ons And All-Motor 7 04-25-2007 09:24 PM
