Radio Antenna + sub / amps issue. - 8th Generation Honda Civic Forum
Old 06-28-2009, 02:05 AM   #1 (permalink)
edit-
we had it working for a few hours., than as i powered the car off there was a hum from thesubs. now i tried to turn the subs back on and no go. music plays amp is on. get .2volts from the speaker outs from the amp. subs = no go. we used KNOWN good subs from my friends car and even his subs didnt work. no fuses are busted line out converter hooked up properly. any ideas guys?
My friend was installing an amp and subs for me and he accidentally snipped the antenna wire, we thought, oh no big deal, until we tried to connect the two wires together.
there were copper strands and then there was this thin plastic rod inside, looks like a fiber optic cable?
now there is nothing but static and only receives actual FM / AM radio signals only if someone touches it and squeezes it.
is there a way to reconnect this or do i have to just replace it
the next issue!
i have two 12'' hifonics subs, hooked up to a CRUNCH 1kwatt amp.
both won't hit at the same time hooked up as Stereo. They both hit in mono., but they do work.... they are in a 2-12'' enclosure hooked up correctly.
Amp = crunch PZi250.2
Subs = HF112D4
hooked up as parallel, settings are on FULL, STEREO.
if you guys could be so kind as to answer
1. the issue with the antenna wire, which we also used as the remote to hook up the subs
2. how only one sub hits at a time.
3. and why it only hits as im on the gas and when i let off it stops hitting
xicetx is offline
Old 06-29-2009, 11:36 PM   #2 (permalink)
I'm not certain, but I think the antenna cable is coaxial (the inner plastic is probably just for insulation). If it's coax, you may have to just replace it . I've never had good luck fixing that kind of wire.
If your amp supports high level inputs (most modern ones do), you should just tap into the factory sub's wiring. That way you can control the level (a bit). Also, you can simply split and splice that wire into the L and R inputs to your stereo amp (what I did).
If you are seeing some issues with louder bass during acceleration, you either have a damaged alternator/battery, or you are drawing too much power from ur electrical system and you may be damaging it. Consider a higher power alternator/battery and a high capacity capacitor.
GalaxSIGray is offline   Reply With Quote
alpine sub/amps NHBP07 I.C.E., Electrical, Security, & Navigation 10 08-18-2007 09:11 PM
Radio Antenna The1SloR/T Mechanical Problems & Technical Chat 7 03-10-2007 02:31 PM
