oil cooler coolant leak
anyone else have this problem? im getting a small leak that forces me to refill the overflow every few months. got some time so i might as well fix this problem. its coming from the bottom hose of the oil cooler. the hose has been replaced twice with new clamps and it still leaks. im sure it leaks more during normal operation but i can only notice a small puddle under the car after letting it sit overnight.
#7 (permalink) | |
Did you notice any corrosion or calcification on the oil cooler inlet or outlet pipes when you removed the leaking hose? If so, perhaps the hose is not sealing against the pipe properly. Or, perhaps the oil cooler o-ring is leaking and it's flowing onto the hose when driving. I don't see how the same hose can be the problem after you just replaced it. Just so everyone knows, the oil cooler is where the oil filter goes (on the Si). Last edited by The Power of Dreams; 06-27-2009 at 11:01 PM. |
| Coolant leak causes dealership to take my car away | ro.sniper | Mechanical Problems & Technical Chat | 30 | 01-28-2009 10:49 PM |
| Oil Cooler / Oil Filter Relocation Kit | blue1 | Forced Induction And Nitrous | 9 | 08-24-2007 10:59 PM |
| Coolant leak | CaliGuy | Mechanical Problems & Technical Chat | 18 | 07-18-2007 11:58 PM |
| Coolant Leak | untouchablesi | Civic SI | 1 | 10-06-2006 04:23 PM |
| Coolant Leak | Jasonbergmann | Mechanical Problems & Technical Chat | 5 | 07-07-2006 11:52 AM |
