Old 10-04-2006, 11:54 AM   #1 (permalink)
Drop in Gas Mileage
I bought a new 2006 Civic LX in June, and have really enjoyed the car. I did notice one thing that has me wondering if this is typical or not.
I track my gas mileage, and over the first 4000 miles, I maintained about 31 miles per gallon. This was over the summer months with my AC blasting. Since then, the weather has cooled off, and I use the AC less, but my gas mileage has dropped to around 28 miles per gallon. Is this typical? I'm now at 6000 miles and about to do my first oil change. I'm a bit surprised with the drop, though. Any ideas on what might be causing it?
mrossini is offline   Reply With Quote
Old 10-04-2006, 12:30 PM   #2 (permalink)
DSchrag's Avatar
Okay.
First: AT or MT? If you're driving a 5spd a change in diving habits (which sometimes you may not even notice as you get more used to a car) can account for this.
Second: I would like to assume you have stayed up to date on your minder codes.
Third: Has the type of driving you have done changed since the summer? Is there a new place of work or a different route? Has traffic flow increased now that the Autumn is here?
DSchrag is offline   Reply With Quote
Old 10-04-2006, 12:30 PM   #3 (permalink)
J-StarR's Avatar
You'll probably notice your gas milage increase again after the oil change.
J-StarR is offline   Reply With Quote
Old 10-04-2006, 02:15 PM   #4 (permalink)
Tx and driving habits
My car is an Automatic. As far as driving habits, my car is primarily for commuting, with my route and driving habits remaining the same. I just received my first maintenance minder, and will perform the service this weekend. Hopefully the first oil change will impove my gas mileage.
Old 10-04-2006, 02:32 PM   #5 (permalink)
DSchrag's Avatar
Get back to us after the service. Your oil is most likely getting all grimy and nasty.
Old 10-04-2006, 02:39 PM   #6 (permalink)
Sli(ks's Avatar
Yeah, I have an LX and my oil life is at 30% with 4,300 miles on the odometer - and my mileage has dropped as well.
So I'd agree with everyone else and say it's probably the oil.
Sli(ks is offline   Reply With Quote
Old 10-04-2006, 04:11 PM   #7 (permalink)
gbae007's Avatar
Check tire PSI. 32 is OEM but I run 35 for economy.
Old 10-04-2006, 09:41 PM   #8 (permalink)
dude's Avatar
Do you fill at the same gas station?
If you live in northern climate the drop can be explained with the fact that the gas sattions haven't switched yet to winter gas...
dude is offline   Reply With Quote
Old 10-04-2006, 09:49 PM   #9 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
You haven't changed your rims and tires, have you? I'm willing to bet it's a combination of oil + tire pressure. Similarly to your situation, my gas mileage dropped at around 5000 miles and after I did an oil change and filled my tires w/ 36 PSI, all as better than it originally was.
Old 10-04-2006, 09:53 PM   #10 (permalink)
Wow, 28-31 in an LX. I just checked mine and I got 29.7 in my SI and not driving like a wus either. I guess I must have above average shifting habits as far as gas milage is concerned. I'm surprised im at the range of what an LX got.
cmd546 is offline   Reply With Quote
Old 10-04-2006, 10:53 PM   #11 (permalink)
dorkiedoode's Avatar
Kevin
man my si only get lik 23 (first manual car that y)
dorkiedoode is offline   Reply With Quote
Old 10-04-2006, 11:18 PM   #12 (permalink)
i had no idea changing your oil would effect your gas mileage. So if i change my oil (still at 4k miles) it should improve? Because i'm getting pretty crappy #'s right now
Old 10-05-2006, 01:47 AM   #13 (permalink)
Smooth Moderator
wing_gundam's Avatar
Civic Type Stock
Well if you look at my stats - ive been getting great economy lately. *cough* 38 MPG
Trying to sell? Read the updated for sale forum rules here
wing_gundam is offline   Reply With Quote
Improve gas mileage drastically. ballplaya4237 Garage 77 12-15-2007 10:02 PM
hondata and gas mileage eugenekim.net Bolt-Ons And All-Motor 4 09-06-2006 06:25 AM
gas mileage and new muffler... hoanger Bolt-Ons And All-Motor 4 09-06-2006 12:34 AM
My Gas Mileage To Date jc21 Garage 21 07-16-2006 12:07 AM
whats your gas mileage? 2evolved Civic SI 5 06-09-2006 02:03 PM
