Old 10-03-2006, 07:33 PM   #1 (permalink)
reelbigfish241's Avatar
Jason dSLR Squad #27
Thumbs down fogged up fog light on the inside-- what to do??
(If you don't feel like reading, just read the cliff notes at the bottom, haha)
ok, so anyone on here that lives in the West-Northwest Chicagoland area knows we got hit damn hard last night by storms.
I have night classes on monday and wednesday, and last night it rained hard. Very hard and very long. The streets flooded in no time because of all the leaves clogging the sewers.
Anyways, As I was driving home I did my best to avoid all the flooding because of my CAI.
I had to take many detours, but I hit one flooded road because I ddin't see it coming (about 4 or 5 inches of standing water).
And then a different road was completely covered in water, all 4 lanes and the median. Some cars were going through, but there was no way in hell I was going to risk it. So I turned around in a parking lot and right when I turn in the parking lot dips and I was in water about 8 inches deep. I idled the car (so i could do my best to avoid hydrolocking) to a dry spot to the right and wiggled my way out of the parking lot.
I finally got home more nervous than anything. I luckily didn't hydrlock my car and I thought I was in the clear.
But when I woke up this morning I looked at my fog lights and they were all fogged (no pun intended) up on the inside. Is there anthing I can do or should I just leave it alone and it'll go away?
The horn was also messed up, but it seemed to clear up after a few times using it, which I thought was strange.
Cliff Notes: Drove through a large puddle by accident, foglights are fogged up on the inside. What to do now?
reelbigfish241 is offline   Reply With Quote
Old 10-03-2006, 08:36 PM   #2 (permalink)
cloudbreakmd's Avatar
Tell your dealer that the last time it rained hard your lens fogged up and you want them to fix the light assembly.
cloudbreakmd is offline   Reply With Quote
Old 10-03-2006, 08:45 PM   #3 (permalink)
I probably should've added their the K2motors fogs. I never had any problems with the rain, just this time after hitting a large puddle.
So bringing them to the dealer probably wouldn't do me any good.
Thanks for reading and giving your input though, I appreciate it.
Old 10-03-2006, 10:24 PM   #4 (permalink)
You can remove the lenses (if accessable) and blow dry them. Then you can always cut a new thicker gasket to put in place. Just a thought.
Old 10-03-2006, 10:58 PM   #5 (permalink)
ShaneWdrd's Avatar
Shane Woodard
Installation manual says this is normal and should go away on its own. Go to www.collegehillshonda.com and read the .pdf
ShaneWdrd is offline   Reply With Quote
Old 10-06-2006, 06:44 PM   #6 (permalink)
ok, so i waited to see if the fogging would go away on it's own and it's still there after 4 days.
Then today, my right fog light bulb went out. Are these fogs even salvagable? Or should I just order a new set on ebay?
this blows
Old 10-08-2006, 02:37 PM   #7 (permalink)
ok, so I today I got sick of the fogging in the lights so I did something about it.
I had to change the bulbs because they both went out. So as I was changing them, I took a right angle screw driver, taped some paper towel to it, and soaked all the condensation off.
It worked surprisingly well. The only problem was that because I tried to wait it out and see if it would go away at it's own, I guess the water ate away at the silver paint. As I was wiping the water off, it also took some of the paint off.
This only happened on the left one, and now I'm gonna see if it affects anything. If not, then great. But if it does either I'll try to repaint it, or just order a new set off ebay.
Just thought I'd post this just in case if this happens to anyone else.
what a pita.
Old 10-08-2006, 05:26 PM   #8 (permalink)
BLU BY U's Avatar
drill a hole in the bottom of the fog so the lights can breath. had to do it with crx headlights and tailights.
Old 10-08-2006, 06:53 PM   #9 (permalink)
hmm, good idea. Next time I'm not doing anything I'll take the bumper off and try it.
thanks guy
Old 10-08-2006, 08:08 PM   #10 (permalink)
BLU BY U's Avatar
no problem, just a small hole at the bottom.....this does 2 things
1: Allows are inside fogs to stay the same humidity level and temp. as outside
2: Allows water vapor to drain out if it does accumulate
Old 10-09-2006, 12:57 AM   #11 (permalink)
radiocontrolhead's Avatar
Danny
cant' watr get in easier
Old 10-09-2006, 02:28 AM   #12 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
Don't make a huge hole. A small 2 or 3mm hole would be fine and any water that can get through that will evaporate from the intensity of your fogs anyways.
it looks like a rock cracked my fog light eugenekim.net Mechanical Problems & Technical Chat 10 11-14-2006 01:19 AM
Fog light film subfree Lighting, H.I.D.'s, & Neon 1 09-20-2006 03:35 AM
Cut-out fog light opening for CAI? crazyj Bolt-Ons And All-Motor 11 09-02-2006 10:27 PM
FOG LIGHT HELP wargate Mechanical Problems & Technical Chat 0 08-30-2006 12:23 AM
Fog Light Question Sprecher Lighting, H.I.D.'s, & Neon 6 05-13-2006 10:40 PM
