Old 10-02-2006, 07:54 AM   #1 (permalink)
fesersoft's Avatar
Is this where the "Oil Leak" is that some have had fixed?
I know some people have complained about an oil leak and have had honda fix it.
I will be taking it in for the 25k service, I will bring it up, but I want to get your input as well.
Thanks
Here are some pics
As you can tell, its not coming from any dripping of the filter, and it is not below the point where the oil is poured in.
fesersoft is offline   Reply With Quote
Old 10-03-2006, 07:37 PM   #2 (permalink)
NoMoreHonda's Avatar
i got mine done.
I had the same problem since the first day of driving but I did not notice it until 8,000km because I never thought that a brand new car would have an oil leak.
I got mine done at 8,000km. they took 2 days and offered me a rental car.
They said it was the headgasket in the engine.
They had to wait for the part to come for a day, then they took another day to work on the engine.
last week, i got my rear shocks replaced.
this week, i'm going back to the dealer again because i have some noisy coming out from the right front corner of the car when i drive over little bumbs.
I hope you are not as lucky as i am.. getting all these problems =P
Good LUck!!
NoMoreHonda is offline   Reply With Quote
Old 10-03-2006, 07:40 PM   #3 (permalink)
fesersoft's Avatar
They pulled a few covers off, everything was dry. They think that the last tech was sloppy at doing an oil change.
They cleaned off the engine and want me to come back in a few weeks to see if anything shows up.
And they would not put the latest HDS on the car without a tsb.
Old 10-03-2006, 09:24 PM   #4 (permalink)
Good LUck!!
Don't worry I am more unlucky than you. I have a myriad of issues and I have setup an appointment with Honda Car Line assistance to see if they can fix some of my issues including the clunk of small bumps and such.
Old 10-03-2006, 10:04 PM   #5 (permalink)
radiocontrolhead's Avatar
Danny
lol, that doenst' look like a sloppy oil change job. lmfao. that tech is an idiot. that gasket is leaking.
Old 10-04-2006, 11:17 AM   #6 (permalink)
Kakashi's Avatar
i had this issue, it was a faulty gasket, took them 3 days to fix
coverty by warranty + POS Neon rental car
Old 10-04-2006, 12:00 PM   #7 (permalink)
fesersoft's Avatar
Your leak was in the exact same place?
They seem to think it's not the gasket, but we will see.
Joe
Old 10-04-2006, 12:38 PM   #8 (permalink)
i guess i dun have the worst civic here =P
i also have an appointment with HOnda this friday.
the dealer manager actually called me yesterday cuz she felt sorry for me, i guess, and asked me to bring it back to the shop if i had more problesm.
and of course, i still have a bunch of problems that need to be fixed.
Old 10-04-2006, 12:41 PM   #9 (permalink)
Joe
does ur car accelerate fast enough ? because when i had my oil leak problem with the gasket, my car wouldn't accelerate fast. It took forever to hit 100km/hr.
Old 10-04-2006, 01:18 PM   #10 (permalink)
fesersoft's Avatar
I think 0-60 is around 8.5s or so, right in line with the specs.
Old 10-04-2006, 01:28 PM   #11 (permalink)
Kakashi's Avatar
actually it was more then that, they said it was a faulty gasket, and thats why my performance was lagging, but they said a majority of my oil leak was coming from some bolt not having the correct sealant or o-ring, something like that.
Old 10-05-2006, 05:01 PM   #12 (permalink)
Danny
the bolt they are talkign about is most likely the tsb. this is the parts ont he engien that honda screwed up on and many have had leaks. although, i highly doubt leaking oil will suffer times, unless it's substancal. in this case, performance shoudlnt suffer at all, but if enough leaked out, then of course.
Old 10-05-2006, 05:03 PM   #13 (permalink)
Kakashi's Avatar
well i dont have a Si, and i push my FA VERY hard sometimes.
by the way.. spell check please.
Old 10-05-2006, 05:23 PM   #14 (permalink)
Danny
sorry, no, the tsb is for he r18 engines.
Old 01-16-2007, 09:34 PM   #15 (permalink)
Mateen's Avatar
Thanks
Here are some pics
What was the cause of this leak? I have the same leak exactly in the same spot as yours. Dealer told me that's where the transmission is and the leak is from the transmission. They put some dye in the transmission and sent me home.
Was yours a transmission leak?
I have an ex coupe A/T
Mateen is offline   Reply With Quote
Old 01-17-2007, 01:07 AM   #16 (permalink)
fesersoft's Avatar
They claimed they cleaned off the engine because someone spilled oil when they were filling it up.
I took pictures because if it becomes a real problem, I can ensure the claim is not denied, even if it is over 50k miles.
It was cleaned off about 12k miles ago and I am going to do my own oil changes now so I can monitor things closely.
I had it in for a few other issues since then (thermostat, radiator sensor, radiator flush because the part was at the bottom so they had to empty the radiator).
We will see I guess.
Mine is an EX Auto Sedan.
I have no clue what the leak is. If I get more on the engine I will take a sample and see if it can be tested.
Old 01-17-2007, 04:54 PM   #17 (permalink)
Mateen's Avatar
Last time you checked it was 12K ago? Let me know how it looks next time you check it.
Dealer told me that this is the bottom of the transmission and its a transmission leak. Can some one look at those pics and confirm this?
I went to get my car fixed today.. and I spent a few thousand $$ JeShUa Water Cooler 25 10-01-2006 02:41 AM
Mini DIY - Fixed my elusive door rattle PokeyD16Z Do It Yourself Articles 6 09-13-2006 10:17 PM
