![]() Join Date: Sep 2005
I am getting more and more frustrated with my Injen CAI. I did everything the instuctions said and as posted by other members here. I've triple checked my install and everything looks good and everything including the clamps being tight. Also, I was very careful with the MAF sensor when doing the install. I connected the battery back let the car idle for 20 minutes, but 300 miles later I get the dreaded orange engine light. Not once but 3 times.:Mad:
Anyone have any ideas as to what might be the problem?
I reset the ECU by disconnecting the battery for 15-30 seconds. Would having Honda reset it be any diffrent than my method? I know the MAF sensor is very sensitve, should I zip tie the wires to somthing so they don't move around at all? I routed the wires under the intake piping. The screws are tight.
Guest
Posts: n/a
im not sure how exactly you did the wires from/to the MAS
but what i did was removed the entire plastic shroud that covered them from factory and loomed em up. Then tucked them or zip-strapped em somewhere secure. my guess is you have an airleak maybe? as far as the reset on the sensor....it may be different then just removing the battery neg term. |
Marv
make sure the MAF is seated correctly and also the hose conneted to the throttle body is tight and the pipe is all the way in. you might wanna try to keep the battery disconnected to maybe an hour.
![]() Join Date: May 2006
Dumb statement, but best to not overlook it, but you're positive the mass airflow sensor is in the right way?
Have you got the code read? Did you also try retightening your air filter?
2007 Taffeta White Civic Si Coupe |
I have 21,000 mi. The CAI is causing the CEL.
Im pretty sure the MAS can only go in one way, but I'll check. No I didnt have the code read, because I've heard that having someone like Azone plug into the ECU or whatever they hook up to read the code can void the warranty. Dont know if that true or not, and im avoiding the dealer because I don't want them voiding my warranty either. As for the filter when I was installing it I kept screwing the clamp so tight it would make the filter come off, so I wiped away the oil off of the rubber and didn't tighten it down so tight to make it pop off, but its on there good. I can look down by the battery and see it's still on there. If there was an air leak somewhere would I be able to hear it? It sounds very quiet at idle. Thanks for the replies.
#10 (permalink) |
Chester
did u get this fixed? I'm lookin into getting a Injen CAI or a Fujita since they're pretty much the same division..heard the engineers weren't happy with Injen and most of em moved over to Fujita
i got a K&N drop in right now what are your thoughts on the intake since you've had it |
#12 (permalink) | |
#13 (permalink) | |
I really like the looks and sound of the CAI , but not worth a CEL. I'm gonna give Injen a call and inform them of the problem and she what they say.
#15 (permalink) | |
#16 (permalink) |
on some vehicles, not tightening the fuel cap can trip a cel. something about pressure in the gas tank. also, to reset the computer disconnect both battery terminals, and touch them together. this will discharge any capacitors that may be holding enough charge to keep memory. i've also heard you can disconnect your negative terminal, turn your key on and press and hold the brake. otherwise, you will have to leave the neg terminal off for about an hour.
keep in mind that if your radio has a security code, you will need it after you reset your car. i'm not sure if the new civic has this since i don't own one yet. james. 97 civic ex for sale. |
#18 (permalink) |
I doubt it's the fuel cap. The fuel cap message is seen on the odometer display and since the issue has been brought up he has reset the ECU and hopefully has filled up his gas tank.
How is it now Silver8th?
#19 (permalink) |
Well, I reset the CEL by removing the neg battery cable again. CEL stayed off for excatly 500 miles. I took the car to Advanced and Autozone and neither of their code checkers could connect to my car for some reason. I even made sure it was plugged all the way in and had them try the test 3 time each, nothing. Guess I'm gonna be forced to take it to the stealership to see what the problem is.
#20 (permalink) |
Purpul Plane 4ever!
![]() Join Date: Jul 2006
I know the MAS has been talked about, but when I installed my CAI on the Si I could put the MAS 2 different ways. Basically did a 180 degree placement on it. Both fit well and tight, but one seemed to somewhat click into place. In your pic you have the wires facing away from the injen label. Try putting the MAS were the wires are on top of the injen label.
| DIY: Injen CAI install on R18 (lots of pics) | peliROJO | Engine | 168 | 02-04-2012 02:53 PM |
| Injen CAI vs AEM CAI Review....hesitation etc. | sickyute | Intake & Spacer Discussion | 133 | 09-21-2011 04:02 PM |
| Check Engine Light - Tried everything, double check my install? | Yodums | Bolt-Ons And All-Motor | 51 | 03-12-2010 11:36 AM |
| 2006 check engine light and dont go over 3500 rpm | bodydraggin | Mechanical Problems & Technical Chat | 15 | 07-21-2008 09:48 PM |
| Need the Injen CAI Part # for R18 Engine | Yodums | Intake & Spacer Discussion | 8 | 08-07-2006 12:56 AM |
