Old 09-22-2006, 09:27 PM   #1 (permalink)
CaliGuy's Avatar
J. M. back by popular demand!
Comptech ss 1-2nd grind issue
So I installed my Comptech ss yesterday and I noticed that when shifting from 1-2nd gear I grind a tad...only when shifting very fast (which I like to so). If I shift a bit slower it's all good. My buddy at work said that he thinks the I'm shifting too fast for the syncros (or something to that effect).
Anyone else have this issue?
BTW I love this ss!
Old 09-22-2006, 09:32 PM   #2 (permalink)
htec17's Avatar
that is normal even with it stock type s a si have that problem
htec17 is offline   Reply With Quote
Old 09-22-2006, 10:25 PM   #3 (permalink)
O6 Si's Avatar
Luis²
i do the same thing i just slow my shifts down from 1st - second
O6 Si is offline   Reply With Quote
Old 09-22-2006, 11:48 PM   #4 (permalink)
Thats one of the reasons that an SS can be bad for you car. It allows the shifter to be moved faster, but the tranny and syncros are still operating at the same speed and trying to match the quick shifts.
DumbasSi is offline   Reply With Quote
Old 09-22-2006, 11:52 PM   #5 (permalink)
CaliGuy's Avatar
Cool, thatnks for the reply's guys. Looks like I'm just too fast for my car lol
Old 09-23-2006, 12:07 AM   #6 (permalink)
BATANG CITY JAIL's Avatar
you know what.. i do like short shifter... but i had an issue before with ss, thy make my clutch pedal squeeks all the time.. even i bleed the clutch cylinder and put like heavy grease on the spring and shalfts.... after a while i get the squeeks again.. i did even change the whole clutch pedal assembly.. but the squeeks is just keep coming back...
and whats the porpose of SS if your slowing your trow on the shifter?? short shifter suppose to slow you time shifting...it dont make sense, on the regular one, you can shift fast but the travel is long, and on SS you shift slow but your travel is shorter... what do you guys think??
Old 09-23-2006, 12:22 AM   #7 (permalink)
CaliGuy's Avatar
^^^Well other than shortening the throw the ss also makes the shifter a lot more "notchy" and "confident" which I like, but you have a good point Batang...
Old 09-23-2006, 12:59 PM   #8 (permalink)
dentrecords's Avatar
Next, get the metal bushings and put those in! I love the way it feels with the short shifter.
Originally Posted by 2fast4u2
yee hawww
Old 09-23-2006, 02:29 PM   #9 (permalink)
esquesk's Avatar
double clutch and your fine
esquesk is offline   Reply With Quote
Old 09-25-2006, 07:16 AM   #10 (permalink)
just act quicker on the clutch...you are probably clutching at the same speed as before the short shift, but moving the lever faster...
Mikagami is offline   Reply With Quote
Old 09-26-2006, 09:29 AM   #11 (permalink)
SonicK20Z's Avatar
Rob
how does changing out or shortening the shift lever affect your clutch pedal? from what you're describing from your clutch problem, a squeaking, popping, etc would be a result of a failing master or slave cylinder... replace, as well as flush your fluids and you should be fine. but the shift lever has no affect on what your clutch does.
also, the problem described in post one of this thread has nothing to do with the SS. it's a common problem on the Si, even stock ones... if you redline and shift too fast on the 1-2, dozens of users report an audible grind. I've learned to slow/time my 1-2 a little better and problem solved.
SonicK20Z is offline   Reply With Quote
Starting Issue /Ignition issue/ - Merged threads cornflake Mechanical Problems & Technical Chat 72 11-27-2008 12:10 PM
Do you think there'll be 2nd gear grind? aznkukuboi Civic SI 25 09-19-2007 11:44 AM
comptech icebox/intake jdspeccivic Bolt-Ons And All-Motor 19 10-14-2006 09:04 PM
2nd gear grind CivicWithNav Mechanical Problems & Technical Chat 19 08-23-2006 07:23 PM
1st and 2nd gear hopping (It feels like it's starving for Air or Gas?) shadowone Mechanical Problems & Technical Chat 21 08-18-2006 11:37 AM
