Old 09-22-2006, 02:58 PM   #1 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
How to remove a stripped screw on the MAF sensor?
I was taking a glance around today and I noticed one of the screws on my MAF has a stripped head. It certainly wasn't me because the last time I tampered with that was when I cleaned it and it was fine. It was either the shop that looked over the intake or the dealership (most likely) because they rechecked all connections including the MAF the last time I brought it in.
I wouldn't have cared so much about the situation, but I just ordered a new intake and I need this mofo out. Any ideas? I'm thinking about dremeling the top of the screw off, but I'm scared I'll cut into the MAF sensor. I think you can also "drill" into the screw, but I'm not too sure on that idea.
Yodums is offline
Old 09-22-2006, 03:13 PM   #2 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
Sears or other hardware stores have a bit you can use to remove stripped screws:
http://www.sears.com/sr/javasr/produ...id=00952154000
8thgenuser is offline
Old 09-22-2006, 03:17 PM   #3 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
Thanks. I'll drop by there now and let you know how it goes.
Yodums is offline
Old 09-22-2006, 03:18 PM   #4 (permalink)
Webby's Minion
8thgenuser's Avatar
Good luck!
Old 09-22-2006, 04:34 PM   #5 (permalink)
Civic4u's Avatar
I used a bit that is smaller than the diameter of the hole. Make sure the bit is used for metal. I would just drill it, 95% of the time come out very good
Civic4u is offline
DIY: Injen CAI install on R18 (lots of pics) peliROJO Engine 81 08-14-2008 05:21 AM
How do I clean the MAF sensor on an R18? Yodums Mechanical Problems & Technical Chat 20 04-14-2007 08:18 PM
