Old 09-22-2006, 08:57 AM   #1 (permalink)
SacrificeTheory's Avatar
Chris
Need help with Fogs
Alright, I was able to put the fogs into the bumper and have the wiring go from one fog to the other, but then comes the problem. How do I connect the two wires through the engine? Where do I run the wires through so that it can reach inside. Where exactly should it go around the engine section? Also, My second set of wires seems to be different than the OEM fogs. I bought that "JMD yellow" fogs on ebay. Could someone tell me where each part goes in the car? It would be much appreciated.
SacrificeTheory is offline   Reply With Quote
Old 09-22-2006, 10:07 AM   #2 (permalink)
CivicWithNav's Avatar
you don't....1 wire set connects behind the windshield reservior and one set connects under the steering wheel
Old 09-22-2006, 10:15 AM   #3 (permalink)
benmunger's Avatar
black is ground
benmunger is offline   Reply With Quote
Old 09-22-2006, 10:34 AM   #4 (permalink)
EX2006's Avatar
Cool Fog light help
http://www.collegehillshonda.com/ins...oglightkit.pdf
Go to the link above. It's the instructions for the OEM foglights. The harness you are showing looks like the one that goes under the steering wheel. It gets a little tricky when installing so read everything over carefully. I installed some OEM's into my 06 EX Coupe yesterday. Hope this helps.
EX2006 is offline   Reply With Quote
Old 09-22-2006, 10:39 AM   #5 (permalink)
benmunger's Avatar
Originally Posted by benmunger
black is ground
seriously, now.
do you have pics of the backs of the fogs, the other harness, and the back of the switch.
Old 09-22-2006, 10:45 AM   #6 (permalink)
Chris
Well, this is the kit it came with:
Old 09-22-2006, 11:20 AM   #7 (permalink)
whitecivicsi's Avatar
Well it looks like he only have two sets of wires. Which is a pain in the ass to install. I've seen somewhere on here the someone actually made it work.
The OEM fogs has three sets of wires. One set is to connect the fogs to each other. one is to connect the fogs lights to the hardness behind the water tank to car. Then last set of wires connects under the stearing wheel.
If I were you look at the document from collegehills honda website and try to figue it out. I think you're going to have to be creative here. They didnt send you the OEM wires (or similar to OEM) so goodluck bud.
I wish I can help but can't seem to remember how they did it!
whitecivicsi is offline   Reply With Quote
Old 09-22-2006, 12:44 PM   #8 (permalink)
Chris
So is there no guides out for just the two wire fogs?
Old 09-22-2006, 12:52 PM   #9 (permalink)
I'm sorry man I dont know exactly how to do it but some of the guys either here or fgcoupe.com got it to work. It involves cuting and splicing some wires.
I wish I can be of more help bud. Sorry. There is this other option. You can go to honda and buy the actual wires off of the OEM fogs themselves. It runs around 100$ bucks.
Old 09-22-2006, 01:03 PM   #10 (permalink)
can u separate the wires?
i can see the hook up for the fogs but not the other end of that wire which connects to the front end of the car.
the other set should be color coded(at least mine was) making the install quite a breeze
Old 09-22-2006, 01:04 PM   #11 (permalink)
Did you get your Foglights from trendgear perhaps?
wargate is offline   Reply With Quote
Old 09-22-2006, 01:18 PM   #12 (permalink)
Chris
Yes I did.
Old 09-22-2006, 02:52 PM   #13 (permalink)
Civic4u's Avatar
Should have read the forum before purchase, sorry for your problems. Here a good quote of our member.
"This project took me a while to finish because of problems with trendgear, dynasty and k2motor. Trendgear was the worst. Wrong harness, only two, they won't fit to honda's and no instructions, not even the template to drill hole. They did not returned my email. I wonder how many bought fogs from them from this forum. Dynasty, wish I had them but after weeks of waiting, nothing, emailed them they said it got damaged and i got a refund. Looked at k2motor, made sure that the item in the picture has all the harness mentioned in the honda's instructions. I did not get my fogs from k2 until the 2nd week. I have to confirm that they received my payment and also to send me tracking of the item shipped. I think they forgot to ship it, just my luck! So today I got the fogs and I just have to finish the job. So it is done.
Installation is not that diff. Plug and play. The harness are the same behind the bumper but the switch harness does not have the violet and the blue??? that you plug in. only the red and white. make sure you got the right tools and hmmm. I am not sure about the quality of the lights, but i can change those easily. whew! that's it. I am satisfied with my car except my horn..."
Civic4u is offline   Reply With Quote
White or Yellow fogs? 59FIFTY Lighting, H.I.D.'s, & Neon 9 12-02-2008 12:39 AM
Are Si's fogs size of the lens the same as the sedans fogs? PR8thgen<ivi> Lighting, H.I.D.'s, & Neon 10 12-04-2006 12:28 AM
Yellow or Light Smoked lamin-x Fogs? PR8thgen<ivi> Inside and Out 13 09-04-2006 12:31 PM
For those who installed Injen CAI and fogs.... 1coole60530 Bolt-Ons And All-Motor 19 07-31-2006 02:52 PM
