Old 09-22-2006, 12:58 AM   #1 (permalink)
waross's Avatar
Window Problem
I have had my SI for six months and have had the windows tinted since week one. I never have had a problem with the windows going up or down until this week. When I begin to power the window down the glass catches the rubber weatherstripping and folds it down into the window channel and then the window struggles to go down. When I power it up no problem the weatherstrippign goes back into place. I know this is not right. I looked at the weatherstripping adn it appears that part of the "fuzzy stuff" (for lack of a better term) has been rubbed of right along the edge. Wondering if anyoen else has come across this problem. I figure I will have to get the weatherstripping replaced in order to solve the problem. Oh and it is the wetherstripping on the inside. Only thing I have done recently lately is switch window cleaners after reading all the posts on Perfect Glass. Could this stuff possibly melted the "fuzzy stuff" off the weatherstripping. HELP!
waross is offline   Reply With Quote
Old 09-22-2006, 01:20 AM   #2 (permalink)
ShaneWdrd's Avatar
Shane Woodard
I had the same problem. Is the fuzzy stuff toward the rear coming up on the window?
I had to take my door panel off and staighten it back up, it wasn't hard at all. The part toward the front gets folded down when they are tucking the tint. It normally pops back into place with your first roll down but the strips are very plyable.
I tried coat hangers and eveything else the only way I fixed it was to take off the door panel straighten it and put it back on. Look in the DIY threads to find out how to get the door panel off. Again its not hard - good luck
ShaneWdrd is offline   Reply With Quote
Old 09-22-2006, 01:22 AM   #3 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
I had the problem in my rear driver side door. Brought it to the dealership and they couldn't fix it.. they had to order a whole new piece in and now it works fine. :)
Old 09-22-2006, 01:25 AM   #4 (permalink)
ShaneWdrd's Avatar
Shane Woodard
Thought of another thing. If it is folded real bad and doesn't want to go back try some heat and see if the rubber has any memory. Probably doesn't but its worth a shot.
Old 09-22-2006, 08:18 AM   #5 (permalink)
miles10238's Avatar
bring to deller they'll fix it, they fix mind FREEEEEEEEEEEEEE
miles10238 is offline   Reply With Quote
Old 09-17-2007, 10:32 AM   #6 (permalink)
Angry
I have the exact same problem!! if you figure it out let me know and vice versa...I have been looking around for a silicone based windo cleaner (for lubricant) but i havent found one yet
vtwinjunkie is offline   Reply With Quote
Old 09-17-2007, 11:18 AM   #7 (permalink)
Dont get eaten!!
Phalanx's Avatar
Ski-Free Monster
I have the same problem.... but with the window going UP! It started immediately after my windows got tinted.
It only happens on my passenger side... the driver side works fine.
Taking tot he dealer today when I get home from work.
build thread
"A car never breaks. It presents us with opportunities to upgrade."
Phalanx is offline   Reply With Quote
Old 09-17-2007, 11:35 AM   #8 (permalink)
JCool's Avatar
Jared
I put tint on my windows and didn't have any problem but I would take it to the dealer they sould be able to fix the problem. they might charge because they would say it was the tint that did it and not a factory problem though. but that would be your best bet.
JCool is offline   Reply With Quote
Old 09-17-2007, 03:43 PM   #9 (permalink)
hey all I used plexus (wich is a kick a$$ plastic cleaner) on my window and it solved the problem instantly! i would recommend trying it before you go to the dealer....it acts as a lube for the window and the weatherstripping
Old 09-17-2007, 04:05 PM   #10 (permalink)
Dont get eaten!!
Phalanx's Avatar
Ski-Free Monster
where did you buy? and how much?
build thread
Old 09-18-2007, 08:52 PM   #11 (permalink)
you can get it at any motorcycle shop...or just research it online
Old 09-19-2007, 12:22 AM   #12 (permalink)
06CivEXJon's Avatar
Jon
Does your windows also go up or down slowly or seem to struggle? or does your door panel pop or flex when the windows roll up or down? RPMS rise?
Old 09-19-2007, 03:45 PM   #13 (permalink)
before I used the plexus on the window tint side, the door panel would pop out a little as the window went down and yes it did seem to struggle because the weatherstripping would flip down due to catching the window but when I sprayed on the plexus (plastic wax) and then wiped it off the problem instantly went away!
Old 09-19-2007, 03:50 PM   #14 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
this happens because the person wo tinted the windows has to push the weather stripping down into the window to get the tint to go below that strip line. and because you can use the window the stripping gets stuck there. if you keep using it that way it willl damage the stripping and you will need a new one.
Originally Posted by NBPRudy View Post
:failmyharryballs:
http://killyourself1.myminicity.com/env build my city.
Zeuceone is online now   Reply With Quote
Old 12-17-2007, 05:27 PM   #15 (permalink)
actually for my situation that had no part in it whatsoever I actually made him redo it 2 times and watched him both times do it CORRECTLY...I think it may have had to do with the type of tint he used or maybe my weatherstripping was starting to dry out because after I used the plexus it worked perfectly...now everytime I wash my car I clean all windows that have tint with the plexus and its great!!
DIY Auto windows thread *merged* letsgoflyers81 Electrical 61 12-02-2008 02:13 AM
Wind Noise- Driverside Window berne Mechanical Problems & Technical Chat 3 06-19-2006 07:37 PM
Look at the problem this poor guy had with rear window GregM Mechanical Problems & Technical Chat 10 04-08-2006 02:09 AM
2006 Civic sedan rear window clm10k Civic Coupe And Sedan 5 01-07-2006 04:23 PM
