secondary 02 sensor - 8th Generation Honda Civic Forum
Old 04-21-2009, 08:29 PM   #1 (permalink)
secondary 02 sensor
Has anyone had to replace their sensor yet becasue of the race header and/or nitrous use? If so, how hard was it and pictures would be great!!!
Thanks
Dan
Dan1981 is offline
Old 04-21-2009, 08:58 PM   #2 (permalink)
DavisLasVegas's Avatar
Dave
it depends if you have a k20 or r18, i personally have an r18 and could probably change both 02 sensors in less then 10 minutes. but i believe the k20 is a bit longer
DavisLasVegas is offline   Reply With Quote
Old 04-21-2009, 09:14 PM   #3 (permalink)
FUBAR_Fiji's Avatar
Shane
About 2 months ago I got the reading. My defouler was good for about 2 months before the light came on. I have a Strupp race header.
We went and took the defouler off that came on the header and bought a 2 pack of spark-plug defoulers. Drilled a hole through one of them so the sensor would fit, screwed it on the back of the other, screwed it into the header and put the sensor back on.
I know it sounds cheap but it does work.
I doubt your sensor is bad.
FUBAR_Fiji is offline   Reply With Quote
replacing secondary (behind the "cat") o2 sensor Civicn33b Bolt-Ons And All-Motor 16 12-15-2009 08:30 PM
how to remove 02 sensor? jdm free Mechanical Problems & Technical Chat 5 04-17-2009 04:07 PM
Greddy 02 sensor adapter ryanmcm83 Turbocharging 2 04-10-2009 01:07 PM
02 secondary sensor??..HELLPP!!... koukou0o2 Mechanical Problems & Technical Chat 13 04-06-2009 04:13 AM
02 sensor primary slow4drsi Mechanical Problems & Technical Chat 1 04-03-2009 11:28 PM
