Thermal protector replacement: 2002 Honda Civic LX - 8th Generation Honda Civic Forum
Old 04-21-2009, 06:10 PM   #1 (permalink)
chc
The A/C of my 2002 Civic LX has not been working for a while, I troubleshot it last weekend and found ECM/ECU doesn't send command to clutch relay. I thought maybe ECM/ECU needs to be replaced which will cost $400 for just part.
I brought my car to a local mechanic this morning, after 1.5 hours ($127+tax) they told me the thermal protector is actually bad, part will cost $75, but installation will be 2 hours/$170. Since I have ~106k miles on the car, they also recommended to replace timing belt/water pump/drive belt/antifreeze for $600. If I do it, the cost of installation of thermal protector will be 0.5 hours/$42.
I am happy that the cause of A/C failure is not ECM/ECU, but I am not sure if the installation of thermal protector will cost that much. I would like to get your opinion if it will really take 2 hours, and if I can install thermal protector by myself (not very skilled, but can do oil/wheel/brake change reasonably well). If I can't do it by myself, I might consider to do timing belt replacement at the same time.
Thanks a lot.
chc is offline
Thermal Protector Set-HELP a poor girl out! jessssica Mechanical Problems & Technical Chat 4 05-09-2010 10:59 PM
what do you think of white wheels on a black 2002 lx? aznmunkeyx Wheel And Tire Upgrades 7 11-04-2008 09:20 AM
Honda on Honda abuse: my 06 civic LX hit by 03 odyssey @30 mph bgardner23 Mechanical Problems & Technical Chat 5 08-16-2006 10:00 AM
