P0139 Question, already searched.
I got the code p0139 with an AEM intake, buddy club rh and LSD kitty backer. I understand the code means 'slow response'. I searched and found one mention of checking the MAF. My intake was sworn by AEM not to work well with any other year but 06, I have an 08. My dyno proved the intake made power, up to 12 whp and 6 hp over max. I do have 'lumpy' problems wit this intake. Like if its got lets say 3 lines of coolant temp when im jsut heading to work and i go past half throttle any where under 3500 rpm, my face is in the steering wheel with what feels like detonation. With the stock intake its as clear as a whistle, i can mash anywhere with no problems. i had the whole setup on and never had a code till 6k miles or so, then i cleared it and got the same code another 1k later.
So im just wondering if it is the intake. |
Absolut Alcoholic
More than likely the wires are shorting out. The car is also probably staying in open loop, so my guess is that the heater is bad. The code is saying the 02 sensor is intermittent. It should be the one just prior to the cat. I dont believe we have one after the cat.
did you cut and slpice the 2nd o2 wires when you installed the header? i had to on mine but just for the sake of time and i have a code that comes up as slow response bank 1 sensor 2 but my car doesnt bog or anything i just need to get off my ass and soder the wires together lol
No everything went in with stock components. all wiring. I have had the defouler in sicne the header was put on. There are two 02 sensors btw. one for AFR and one for catalyst efficiency. Wehn i look at my scanner what sohuld i benn in open or closed loop.
#10 (permalink) |
Have you considered a different defouler? I think I read somewhere on here that the code *could* mean that the sensor is not getting enough of a reading from the exhaust flow, therefore the low reading nature of the code. I got the same code, as well as the "stuck rich" code (can't remember the code number), and plan to try a new, shorter angled defouler before I drop the cash on a new sensor.
Funny thing is, I can tell just before I'm going to get the cel... droning in 3-4k range gets louder and mushy sounding. It happens periodically, and eventually goes away after a few days. good luck. |
| Ive searched and searched | TXcivic | Wheel And Tire Upgrades | 11 | 04-02-2009 01:55 AM |
| I searched but cant find | 2006SI | Bolt-Ons And All-Motor | 14 | 03-16-2009 09:34 PM |
| p0139 code | atlprofessor | Forced Induction And Nitrous | 4 | 02-03-2009 12:50 AM |
| P0139 Code | c130turboprop | Bolt-Ons And All-Motor | 8 | 10-20-2008 10:52 PM |
| i need help (i searched but didnt find what i was looking for) | baz938 | I.C.E., Electrical, Security, & Navigation | 6 | 12-27-2007 07:09 PM |
