Old 04-21-2009, 12:29 AM   #1 (permalink)
Will my 08 Si hondata reflash be affected with a e85 conversion kit?
I have a 2008 Civic Si with a KNN Short ram intake.
Rock81953 is offline   Reply With Quote
Old 04-21-2009, 09:55 AM   #2 (permalink)
ryker's Avatar
why have power mods then use a low power fuel like e85? on a n/a engine with stock compression e85 sucks.
ryker is offline   Reply With Quote
Old 04-21-2009, 12:16 PM   #3 (permalink)
bouncer07's Avatar
Turbo vehicles benefit from the E85 convert and large SUV's. We are high compression, will need Premuim grade.
bouncer07 is offline   Reply With Quote
Old 04-21-2009, 07:15 PM   #4 (permalink)
Absolut Alcoholic
SiLentPower's Avatar
Joe
Keep in mind that you will need to increase fuel delivery by 30% with the conversion. IE: bigger injectors. The reflash isnt enough to do that.
SiLentPower is offline   Reply With Quote
Old 04-21-2009, 07:54 PM   #5 (permalink)
liquidr1's Avatar
Dustin
why on gods green earth would you even try to do that to your Si.
FAIL
liquidr1 is offline   Reply With Quote
Old 04-21-2009, 08:13 PM   #6 (permalink)
Absolut Alcoholic
Joe
Its kinda what I was thinking.
Old 04-21-2009, 08:18 PM   #7 (permalink)
ImAuthenticFTW's Avatar
Mike Wagner
E85 has an octane rating of 100–105 hope you guys know that....
ImAuthenticFTW is offline   Reply With Quote
Old 04-21-2009, 08:23 PM   #8 (permalink)
Absolut Alcoholic
Joe
Right, but why would you run it without any forced induction...
Old 04-21-2009, 08:26 PM   #9 (permalink)
Mike Wagner
lets see, higher octane means you can introduce more timing (once tuned) before knock shows it dirty little head. there is a LOT of all motor drag cars that are running on e85, its not just for boosted cars
Old 04-21-2009, 08:32 PM   #10 (permalink)
Absolut Alcoholic
Joe
You are correct, but spending the money on the kit and tuning will almost out weigh the power gains from the kit.
Old 04-22-2009, 12:35 AM   #11 (permalink)
i installed my conversion with 100 miles on the odometer with no problems, the Si has a compression ratio of 11:1 that is really high.
Old 04-22-2009, 08:48 AM   #12 (permalink)
ryker's Avatar
I hope you know octane does NOT = energy content. E85 has a LOWER BTU energy content. So unless your running high compression or high turbo boost to take advantage of the higher octane levels your taking two steps back.
Old 04-22-2009, 09:02 AM   #13 (permalink)
ryker's Avatar
the little r18 econo motor is only 0.5 less!
11:1 isn't high when compared to every other modern car. 11:1 is good for 93 octane. Running e85 at 11:1 isn't taking advantage of the 100ish octane. 12.5-13:1 would be needed to help account for the loss in energy content. Now the question is: can the heads flow that much air? increase CR increases air flow needed.
Timing isn't much of a power increase. Where most people see the power from timing is due to running incorrect timing on pump gas then changing over to "race" gas and then going back to correct timing. Sure there is a slight amount of play each way. But a hondata reflash isn't going to help much at all. Mixes as low as E70 can be labeled for sale as "E85" for better winter/cold starting performance, so you have to be careful if you're building/tuning an engine based solely on E85.
A gallon of E85 has an energy content of about 80,000 BTU, compared to gasoline's 124,800 BTU. So about 1.56 gal. of E85 takes you as far as 1 gal. of gas. remember though the increased octane rating of E85 will never make up for the reduced energy density.
Old 04-22-2009, 09:08 AM   #14 (permalink)
bouncer07's Avatar
I've tuned my last car 99 GSX Eclipse on E85 and I say it benefit turbo than N/A. Going N/A on E85 isn't really a point unless your highly modified all motor. Agian, going stock with E85 isn't going to work. Wait for Hondata to come out with it's ECU- it's coming.
Old 04-22-2009, 10:29 PM   #15 (permalink)
so i read that the reflash also leans the fuel and slightly changes the ignition timing right?
Old 04-22-2009, 11:32 PM   #16 (permalink)
BV1
BV1's Avatar
Steve
I subscribe to Motorcycle Magazine, a few issues back, they MADE there own ethanol out of apple juice, and than proceded to convert a Truimph ST to run on it. Before they even started tuning it, on the first dyno run, HP actually went up.
Octane rating, +30% more fuel helped out I guess. Was a good read.
Steve
Quality > Quantity
www.accesstuners.com
BV1 is offline   Reply With Quote
Greddy Turbo kit/Hondata Reflash? jdmpimp Turbocharging 40 04-13-2009 02:05 AM
E85 SI conversion? icewildabeast Mechanical Problems & Technical Chat 15 08-29-2008 04:21 AM
WARNING 08 Canadian Si w/ Comptech/hondata Reflash Pir8pete Supercharging 10 06-14-2008 06:29 PM
Hondata Reflash for Greddy Turbo Kit jdizzle37 Turbocharging 5 10-11-2007 06:38 PM
