Old 04-19-2009, 01:47 PM   #1 (permalink)
AC problem
When I turn on the AC...the fan is running but i don't feel any cold air at all...Is it the fuse problen or the fan probles
Thank you
schoolarea is offline   Reply With Quote
Old 04-19-2009, 02:04 PM   #2 (permalink)
HonDave's Avatar
Probably out of refrigerant.
HonDave is offline   Reply With Quote
Old 04-19-2009, 02:11 PM   #3 (permalink)
I miss all the meets.
07k20z3ftw's Avatar
Mitch
make sure the a/c button is lit...
07k20z3ftw is offline   Reply With Quote
Old 04-21-2009, 07:46 AM   #4 (permalink)
Ac
It's ON...MAX AC / AC are both on....when i pressed AC button before...I would hear something start to run...sounds like a fan....but now I don't hear anything...
Old 04-21-2009, 07:46 AM   #5 (permalink)
Is it possible that my filter is dirty?
Old 04-21-2009, 03:45 PM   #6 (permalink)
HonDave's Avatar
Yes. Replace your cabin filters. They should be changed every 20,000 miles or so. It makes a big difference if they are dirty.
Old 04-21-2009, 03:48 PM   #7 (permalink)
whitecivicsi's Avatar
Mike C.
cabin filters dirty yea replace it
but a/c not running cold most likely your out of freon/ac condenser has a leak. (which sucks btw if you have the dealer fix it ~$750)
lets hope its not that
whitecivicsi is offline   Reply With Quote
Old 04-21-2009, 04:09 PM   #8 (permalink)
michinsi's Avatar
McTomalds
^ All A/C systems slowly leak refrigerant.
michinsi is offline   Reply With Quote
Old 04-21-2009, 04:33 PM   #9 (permalink)
sh33t_0f_p4p3r's Avatar
Tobie
im on my 3rd blower motor
http://i82.photobucket.com/albums/j243/sh33t0fp4p3r/sh33t.jpg
sh33t_0f_p4p3r is offline   Reply With Quote
Old 04-21-2009, 07:07 PM   #10 (permalink)
volvo9's Avatar
Andrew
Yes, but it's not going to empty out in 3 years or less.
You should take your car to the dealer and have it checked out. If the system is too low to function or empty (and you car isn't 10 years old) there is a leak that needs to be checked out. Unfortunately the condensor on these cars likes to eat rocks.
Old 04-21-2009, 07:11 PM   #11 (permalink)
:nerd:
streetlunatic08's Avatar
El Chapo
streetlunatic08 is offline   Reply With Quote
Old 04-21-2009, 07:13 PM   #12 (permalink)
Absolut Alcoholic
SiLentPower's Avatar
Joe
If you dont feel the engine go under load when the button is pressed, the compressor is to blame. The clutch is probably not engaging. Look at your fuse and relay and make sure they are fine. Test them with a multimeter on resistance to be sure. If they test out okay, you have a leak. It also may be the blower motor resistor if you arent feeling any air at all...cold or hot on full blast.
SiLentPower is offline   Reply With Quote
AC problem mistuhyimstuh Mechanical Problems & Technical Chat 5 07-09-2008 04:34 AM
Question about AC and Max AC KraziAzn Mechanical Problems & Technical Chat 20 06-16-2008 07:19 PM
ac problem maybe ADIDAS1984X Mechanical Problems & Technical Chat 3 05-06-2008 04:32 PM
AC temp reading when max ac is on FG2z_K Mechanical Problems & Technical Chat 7 10-11-2007 06:08 PM
AC problem... not sure if this is symptom of condenser issue... LadyEmily Mechanical Problems & Technical Chat 13 09-25-2007 09:09 PM
