Midas broke something on my poor civic
Hey guys,
I had Midas brake pads on my '06 lx coupe's front wheels for a while and the steering wheel would shake whenever I used the brakes - apparently, it was a heat dissipation problem caused by their crap pads whenever they touched the stock rotor. This morning I took it to a honda dealership and they resurfaced the rotors and changed out the pads for stock pads. What really annoys me is that the genius at midas apparently didn't know what he was doing and destroyed something called a "dust gasket". They took me back and showed me. Apparently, he didn't release the air pressure out of that thing before he put everything back together and the first time the pads were used, it "exploded". I didn't really understand what they were telling me, yeah. Midas test drove it, so I'm thinking they heard it go and then didn't tell me they had f'ed my ride up. Those pricks. I'm just wondering, what is this "dust gasket" thing and if it's even worth repairing - how much would that cost? To me, it just looked like a rubber ring with a hole in it. Honda wouldn't give me an estimate, said I should call Midas and see if it would be covered under the famous brake guarantee they supposedly have. I did, and Midas says it must've been Honda. I doubt that, but they have a point - I don't think I have any way of proving it wasn't Honda. *sighs* moral of the story = never go to Midas! |
Midas is total ****. I have had bad experiences with them. I almost got into an accident one day after they changed my front brakes on my 1994 sentra xe 2yrs ago. They finished the job and told me everything is good. I take the car on the road, the light turns yellow and i had so much space to stop on time.....and guess what? the didn't stop. scary!!, went back to them and yelled at the A hole that did the work to fix it.
#11 (permalink) | |
The problem is Midas, bro. It's not like I knowingly put my safety at risk just to save $25. Yeah, as I said I didn't really get what they were saying. They had something swung up above the pads and on the inside of it there was a little black ring, and they told me they always stick a flathead screwdriver in between that ring and the housing around it to relieve the pressure or something. Last edited by imtehman; 04-18-2009 at 07:07 PM. |
#12 (permalink) |
casey
Sounds like the dust seal around the piston was not seated after they installed new pads and now the seal is cut or worn through. This will allow water in around the piston and will rust. You need to rebuild the caliper and replace the dust seal
#15 (permalink) |
Yeah, there's a boot around the piston. Sometimes, if you don't spray some silicone spray on it before trying to push the piston back into the caliper, you can get a big bubble protruding from the boot as you push the piston it. If you swing the caliper back down with that bubble still there, the pads could pinch it and it could pop. Never had it happen to me but I see how it could happen.
#17 (permalink) | |
the manager said something came loose and i was like wtf?
#18 (permalink) | ||
#19 (permalink) |
Douglas
Midas blew up my friends car. They did an oil change, never put the oil cap back on it. Couple of days go by, his engine blows up.. No oil in the car, it sputtered out and oil was then seen all over the engine from lack of cap. Midas sucks. plain and simple.. Do any of them even have to be certified to work there?
#20 (permalink) | |
| This poor civic | t85konrad | Water Cooler | 6 | 12-11-2008 03:51 PM |
| Midas Vs Changing MTF | nayilsi | Civic SI | 23 | 06-17-2008 04:13 PM |
| poor civic :( | biafra | Introduction & Pictures | 53 | 02-25-2008 12:02 AM |
| Hit A Tire... My Poor Civic! | RCKola1011 | Garage | 9 | 11-10-2007 10:40 PM |
| meet a broke down civic | 4door | Garage | 8 | 10-10-2007 09:42 AM |
