Fujita SRI - 8th Generation Honda Civic Forum
Old 04-18-2009, 03:52 PM   #1 (permalink)
Amir
Fujita SRI
Alright, I got a Fujita SRI put on, and I got a check engine light on my 08 EX, the code is the System too lean. Is this really bad and I should take it off and put it stock? or let me hear your thoughts.
Zoni is offline
Old 04-18-2009, 03:53 PM   #2 (permalink)
enojy's Avatar
eric
did you reset your ECU?
enojy is offline   Reply With Quote
Old 04-18-2009, 03:56 PM   #3 (permalink)
Zeuceone's Avatar
sel it and make your own.
Old 04-18-2009, 03:56 PM   #4 (permalink)
Amir
You think it will actually fix it? and I won't have to worry with the a/f ratios or anything on an EX? not an si haha
Zoni is offline   Reply With Quote
Old 04-18-2009, 04:06 PM   #5 (permalink)
enojy's Avatar
eric
if you didn't reset your ECU by disconnecting your battery during the install, you should definitely do so. it will almost certainly get rid of the check engine light. the car doesn't realize that you've changed the part, and the air flow sensor is receiving a different volume of air, so the ECU thinks something is wrong.
Old 04-18-2009, 04:08 PM   #6 (permalink)
Amir
oh okay, so all I have to do is unplug the negative power of my battery and put it back on? then I'm good to go?
after radio codes.. etc.. :P
Old 04-18-2009, 04:09 PM   #7 (permalink)
Blackmagic88's Avatar
Othello
Blackmagic88 is offline   Reply With Quote
Old 04-18-2009, 04:14 PM   #8 (permalink)
enojy's Avatar
eric
yes! disconnect the negative terminal and pump your brakes a few times until the pedal goes stiff. (give it 5 minutes if you want, i always do, but it shouldn't be necessary.) reconnect the terminal and start your car, and let it idle unattended until it warms up, then shut it off.
Old 04-18-2009, 05:54 PM   #9 (permalink)
Amir
just a quick question..
does it have to be the negative side?
or can it be the positive?
My Fujita CAI for Fujita SRI...good? Charmzone Intake & Spacer Discussion 5 05-31-2008 05:22 AM
Fujita SRI 07SIChic Civic SI 36 04-15-2008 08:37 PM
Fujita SRI Help djthomi Bolt-Ons And All-Motor 11 10-30-2007 12:37 AM
