Old 09-19-2006, 01:51 PM   #1 (permalink)
Kakashi's Avatar
A/T Downshift from 2->1
Hey all, im new around here, ive searched a little bit, and i dont think anyone has brought this up yet, they just dont have this issue..
In my LX sedan(stock), whenever im ready to pull to a >complete< stop at a light or sign, my transmission shifts very noticeably from 2nd to 1st. My chassis kinda jolts forwards, like what happens when u slam the brakes(but not THAT much).
I tested it from 5th gear listening/feeling for down shifts, and its very smooth and fine all the way to to 2nd, then it has the jolt/rocking. ive re-tested on flat/uphill/downhill, it happens whenever i am flat or going downhill, uphill it doesnt occur, probably because of the inclination is affecting the rocking so i dont notice.
Either way, anyone have this issue?, if so, what did u do to resolve it?
If my info provided was too vague, please ask what info you need! :P
PS-if there is tranny problems, my warranty should cover it right? its been a year since my purchase, im a little foggy about it...
Thanks for your time~
Kakashi.
Old 09-19-2006, 02:30 PM   #2 (permalink)
liuh's Avatar
Hubert
i feel the same thing, i guess the car feels like it "loosens up" right before you stop, right?
this downshift + DBW lag + super shift shock = uncomfortable :/
liuh is online now   Reply With Quote
Old 09-19-2006, 02:33 PM   #3 (permalink)
I actually made a thread about it a lil while ago. Apparently its "normal" and although hondas transmissions are effective, they're in no way comfy. If this has anything to do with the DBW lag, there supposed to be a fix coming soon.
Uncomfortable transmission
Old 09-19-2006, 05:47 PM   #4 (permalink)
Kakashi's Avatar
ahhh theres that thread
thanks man
i drive my A/T like a M/T. But that was after 3000 miles, i started experimenting with the A/T. But the jolting thing has always been happening..and in the words of someone else in that thread, it DOES feel like i got tapped lightly by the car behind me, i always gotta turn around and look.
BUT, the shifting into "N" before re-engaging "D1" usually fixes that. But yeah, i hope they get this surging thing fixed, people look at me and think i cant drive a A/T right. Plus its annoying to see my passengers kinda jolt. I dont mind, but im tryin to give peopel a comfortable ride too..
lmao.
o yeah btw 10k miles with Semi-sequential usage = still A-ok.
Old 09-19-2006, 09:16 PM   #5 (permalink)
kenchan's Avatar
my EX sedan is like that too. kinda bugged me in the beginning.... just
got use to it. and like you said, kakashi, i also shift into N before
coming to a complete stop. :)
Old 09-19-2006, 09:28 PM   #6 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
Huh...I haven't noticed a downshift jolt in my EX AT sedan. My previous car was a '94 LX AT Accord sedan, so I just might be used the the whole jolting feeling.
Old 09-19-2006, 10:04 PM   #7 (permalink)
asndragonboii's Avatar
i read in another thread that you shouldnt shift to N while still in motion. I dont know if thats true?
Old 09-19-2006, 10:12 PM   #8 (permalink)
kenchan's Avatar
i only do that less than 7-8mph.. just rolling to a stop. it won't hurt it.
Old 09-20-2006, 12:23 AM   #9 (permalink)
I used to drive a 96 accord, and the transmission was a lot more comfy, dispite some harsh upshifts. This civic's transmission just doesn't really have the driver in mind.
Old 09-30-2006, 01:47 AM   #10 (permalink)
Kakashi.
I only experience this issue when I'm not driving in a legal manner. Basically, if I'm speeding and approach a stop to the point where I barely stop and want to go again, I will have this jolt. If I slowly approach my stops this downshift jolt is non-existant because the vehicle is slowing down in an appropriate manner. I'm going to assume that your problem is identical and recommend you try simply going slower into a stop.
The rocking is basically because the trans is downshifting into a lower gear in a hurry -- causing the car to lurch like when you downshift intentionally to brake the car down a hill or some similar reason. For instance, if you downshifted at 45mph into 2nd gear, you would notice a fairly significant lurch until the car revved down to where it would normally be in 2nd gear.
carlschmidt is offline   Reply With Quote
question on A/T shift knob? wolfxkc Civic Coupe And Sedan 8 05-28-2008 02:00 AM
wasting my money on an A/T transmission ayenoc Inside and Out 20 10-26-2007 10:56 PM
heel and toe shifting good read 2evolved Civic SI 12 09-27-2006 07:23 PM
Driving the A/T like a M/T RockALittle250 Civic Coupe And Sedan 47 09-05-2006 08:19 PM
is it bad to downshift? radiocontrolhead Civic SI 39 05-31-2006 12:59 AM
