HOW to install serpentine belt - 8th Generation Honda Civic Forum
Old 04-06-2009, 06:17 PM   #1 (permalink)
Hi am trying to install serpentine belt honda civic 06 2doors i for got the belt position is possible give me the diagram to install the belt?
thanks for help
imvusa is offline
Old 04-07-2009, 12:23 PM   #2 (permalink)
anybody have diagram the position to install the serpentine belt my hood dont have the sticker
imvusa is offline   Reply With Quote
Old 04-07-2009, 12:37 PM   #3 (permalink)
06k2o's Avatar
Felipe
clear pic of the belt and how it goes... good luck....
06k2o is offline   Reply With Quote
Old 05-24-2011, 11:17 PM   #4 (permalink)
B A H
The local Honda dealer said there is no service interval for changing the serpentine belt, only to change it when it starts to crack. Does anyone know how long these belts are good for as I do not want to wait for trouble. My 06 civic has 120,000 km's on it. Thanks.
civic06bah is offline   Reply With Quote
Old 05-25-2011, 09:33 AM   #5 (permalink)
Stephen
That's a K20, i'm not so sure the OP has a civic si...
w00t692 is offline   Reply With Quote
Old 05-25-2011, 09:46 AM   #6 (permalink)
CraigW's Avatar
I would imagine 80-100k miles would be safe, some cracking on the ribs is normal, but getting close when they do occur. And considering the age you may want to think about replacement.
CraigW is offline   Reply With Quote
Old 05-25-2011, 10:00 AM   #7 (permalink)
Stephen
The main thing you should be checking, if you have an auto tensioner setup, is if the belt is stretched.
There should be markings on the tensioner mechanism.
Old 05-25-2011, 10:14 AM   #8 (permalink)
It would be pretty rare for the belt to just snap on you. Usually the tale tale signs of it going out, are squealing at start up, fraying on the ends, you'd be surprised how long those belts can last.
Now if the belt has been sitting for a long time in the same position, that is a different story, it could snap at that point, but we're talking years of sitting for that to happen.
jongp3 is offline   Reply With Quote
Old 05-30-2011, 05:42 PM   #9 (permalink)
B A H
serpentine belt
for the DIYS people, there is a gauge available that you lay on the v in the serpentine belt, if it sits flush or below the belt is worn,my belt was 5 years old and 120,000 km's on it. My replacement belt was longer than original belt and Honda has decided to change the routing as well(new routing shown on package the belt comes in from Honda dealer).
Old 05-30-2011, 10:45 PM   #10 (permalink)
thanks for help
here's a link on how to install serpentine belt there are more on Honda repair by the way.
carlosshane1477 is offline   Reply With Quote
Old 05-31-2011, 08:24 AM   #11 (permalink)
B A H
when you but a new belt from a Honda dealer the new routing is featured on the packaging,do not follow the photo that is posted below as it is incorrect.
Old 05-31-2011, 11:23 AM   #12 (permalink)
Is the new routing for the R18 or K20??.... or both?
Dirtmagnet is offline   Reply With Quote
Old 06-01-2011, 05:20 PM   #13 (permalink)
B A H
The new routing is for the R18 which is what I have, I do not know about the Si.
Old 06-01-2011, 05:23 PM   #14 (permalink)
B A H
The photo posted looks like it is an Si motor and the routing may be correct, sorry for the confusion.
Old 06-01-2011, 06:49 PM   #15 (permalink)
Aahh ok. I have an R18 too. Just wondering what the advantage of the new routing would be?? Seems like a strange change for what seemed to be a non-problem...
Old 04-06-2012, 04:59 PM   #16 (permalink)
ron
the picture is not the right diagram for the 2006 civic coupe with AC
ron13701 is offline   Reply With Quote
Old 04-06-2012, 05:03 PM   #17 (permalink)
BlkBlue07civic's Avatar
Mat R18 #728
Yes that is an si k20 not an r18
BlkBlue07civic is offline   Reply With Quote
Old 04-08-2012, 12:50 AM   #18 (permalink)
Itsaluigi's Avatar
Luigi
http://www.8thcivic.com/forums/engin...-civic-si.html here a link from one of our member here
Itsaluigi is offline   Reply With Quote
Old 04-08-2012, 12:51 AM   #19 (permalink)
Itsaluigi's Avatar
Luigi
he did a good job of diy what is what on the belt line up
Old 04-08-2012, 12:53 AM   #20 (permalink)
Itsaluigi's Avatar
Luigi
here one for a r18 http://www.8thcivic.com/forums/engin...y-kit-diy.html
Loosen serpentine belt tensioner "slowly" rationull Mechanical Problems & Technical Chat 35 07-31-2012 10:14 AM
Can't re-install Serpentine belt! redpepSi Mechanical Problems & Technical Chat 4 09-14-2008 11:34 PM
Need Help Removing Serpentine Belt (Si)! redpepSi Mechanical Problems & Technical Chat 0 09-14-2008 03:16 PM
Serpentine belt wear line... blkstreak Mechanical Problems & Technical Chat 6 05-15-2007 08:40 PM
Serpentine Belt CNUco2007 Mechanical Problems & Technical Chat 3 12-31-2006 10:22 PM
