Old 09-17-2006, 04:46 AM   #1 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
Unhappy Sticky Door
Is anyone else having a problem opening their door? The left rear door on my sedan is acting up and it took me at least 5 minutes to open it today. I had to push the open and close button on the key and the driver door many, many times before it finally opened. The problem is that it doesn't happen all the time and I have a feeling that when I go to the dealer the problem won't be there. Anyone have any insight on this? Thanks.
Old 09-17-2006, 06:11 AM   #2 (permalink)
chylld's Avatar
what happens when you try to open it? does it act as if it were still locked?
sounds like some gunk (or other obstruction) is affecting the door rod operation - i created that problem for myself with my last car after i dynamatted the door and jammed the door rod :)
chylld is offline   Reply With Quote
Old 09-17-2006, 09:25 PM   #3 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
Yea I push the button to unlock and even physically unlocked the door tab but it still wouldn't open. I've checked it several times and there doesn't seem to be anything outside affecting it, so I suspect it's something inside the door.
Old 09-17-2006, 09:39 PM   #4 (permalink)
chylld's Avatar
well here's a pic of the inside of a rear door with the weathershield removed:
you can see the depression in the top left where the door handle and mechanism fits in... it's possible that some excess goop normally used to hold the weathershield has gotten into your handle mechanism...
if you haven't modified your doors at all though, i'd recommend just taking it up with honda service.
Old 09-17-2006, 10:04 PM   #5 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
Thanks for the help.
Door Lock Tricks (Auto Lock, Auto Open) amdhunter Do It Yourself Articles 96 11-08-2008 07:26 PM
DIY: Ambient lighting in door handles PokeyD16Z Interior Style Mods 65 10-24-2008 10:53 AM
Mini DIY - Fixed my elusive door rattle PokeyD16Z Do It Yourself Articles 6 09-13-2006 10:17 PM
Door edge guards installed [IVI] Inside and Out 14 06-07-2006 12:47 PM
