Noisy Aux Jack
I just installed the aux jack in my CSX. I use it with my XM Xpress unit. I notice a slight background hum with the aux that isn't there when using the unit's built in FM mod. The sound quality is better with the aux, but I'd love to lose that hum. It does not change with engine revs so does that mean it's not alternator noise? The Xpress is plugged in to the lighter socket, I guess that if I tried powering it some other way that would help troubleshoot it. I could also try my MP3 player and see if the issue is the Aux or the Xpress.
Phantom Poster
![]() Join Date: May 2006
Justin aka Mr. JT
How bout running the ground to a ground junction in the wire harness that already exists in the car. If you make any old ground in the car you can get ground feed back wich in this case is what it sounds like.
![]() This happens when stray voltage travels through the car and up into the ground wire that you have created.
Hey... Did you resolve this issue? The only reason I said anything about the ground is that as I was hooking my MP3 player to the AUX plugin when the ground wasn't set just right it sounded like the music was very low - even though turned way up and like it was playing in a cave (hollow, distant, one channel). There shouldn't be a problem though if you're using all the factory connectors - I hacked my connection (a DIY on this forum) so there's a difference. I am curious though about the resolution...
#8 (permalink) | |
I had this problem with my Sirius unit, but the problem is solved now. |
Problem solved (or at least explained). I found that even when I plugged in the XM unit into an AC adapter run from an extension cord in my garage that I STILL had the sound. When I plugged in my iPod directly to the aux jack...no buzz. The problem is with the XM unit not the aux install. I'll live with it. It still sounds way better than the FM mod and it's really only noticeable at VERY high volumes.
| Honda MP3 Aux input jack | George Hamilton | I.C.E., Electrical, Security, & Navigation | 15 | 11-14-2006 03:58 PM |
| 4dr sedan LX aux jack? | reiichiroh | I.C.E., Electrical, Security, & Navigation | 2 | 08-16-2006 09:59 AM |
| Aux jack | liquidr1 | I.C.E., Electrical, Security, & Navigation | 7 | 07-07-2006 04:10 PM |
| ipod aux input jack | aliefnate | I.C.E., Electrical, Security, & Navigation | 1 | 07-04-2006 01:25 AM |
| Civic Si Aux Jack | tim711 | Civic SI | 9 | 06-08-2006 10:41 PM |
