Originally Posted by cAPS
There's no fluid leakage, and it pops during shifts. Has happened 2-3 times.
do ou have the factory tranny mount or have you changed it? make sure the popping isnt actually the tranny banging, i have mine set up with a solid mount and my dampner set stiff, i do feel a solid engagment while shifting. i dont recomend this if your worried about trans problems or a harsh shifter, you can damage balance shafts and shift forks , need to be dead on during shifting..more or less if you can drive an unsprung 6 puck with solid mounts then this may be for you , also if tranny work is not a big deal.
