Old 09-07-2006, 05:52 PM   #1 (permalink)
djdefcon's Avatar
NAV "Auto Lighting" feature Not Working
Anyone else have trouble with the "Auto" feature on the NAV not working properly? It was working, when my headlights are on the NAV gets duller and vice versa when they are off. But the other day it was raining and I had my lights on so I changed the NAV to DAY and then back to AUTO at night, but now the NAV is ALWAYS bright and I have to change it to NIGHT when it gets dark out.
Anyone know why or have experienced this problem before?
djdefcon is offline   Reply With Quote
Old 09-07-2006, 07:21 PM   #2 (permalink)
SSlick406's Avatar
I had this problem until I added my foglights. I think the autodim relies on some kind of initial power draw (turning on the headlights.) I guess adding the extra draw of the fogs fixed this issue. So If the dealer can't fix it hop on ebay, spend about $100, install them, and your problem is solved!
SSlick406 is offline   Reply With Quote
Old 09-07-2006, 07:57 PM   #3 (permalink)
Turn your instrument panel lighting down from max. Just turn it down below the first click of full bright. The navi displays day mode when the dash lighting is on full bright.
gblaue is offline   Reply With Quote
Old 09-07-2006, 08:08 PM   #4 (permalink)
SSlick406's Avatar
That could possibly work also. I was givin the same advise before I installed the fogs and it rarely made the situation any better. Like I said earlier I think it works off of a power spike so sometimes when I rolled the window down, changed a hvac control, or let the car rev low (man trans) it would change to the night mode.
Old 09-07-2006, 08:24 PM   #5 (permalink)
Resident Caraholic
Cybergypsy's Avatar
Yep he is right.....happen to me once too, 2 clicks work
Dreams have only one owner at a time. That's why dreamers are lonely.
Erma Bombeck
Old 09-07-2006, 11:10 PM   #6 (permalink)
Yeah it is one click to dim the speedo one nick then one click to dim the navi down. It does kill the eyes at night.
wargate is offline   Reply With Quote
Old 09-08-2006, 02:07 AM   #7 (permalink)
I had the same problem a few months ago. To fix it I just disconnected the battery for a minute and reconnected it. That fixed the problem and now it works perfectly!
jaig620 is offline   Reply With Quote
Old 09-08-2006, 09:41 AM   #8 (permalink)
sonitex's Avatar
I'm picking up my HRP 06 Si w/ NAV on Monday. I have no idea how and what it does. Is there any downloads anywhere to explain it's operation??? Also, how does disconnecting the battery for a minute correct a problem with the NAV
sonitex is offline   Reply With Quote
Old 09-08-2006, 09:45 AM   #9 (permalink)
2 clicks. I had the same thing happen the first day and I thought it was broken.
mmm def is offline   Reply With Quote
Old 09-08-2006, 10:24 AM   #10 (permalink)
Type X's Avatar
i did some work on my car the other day and when the navi rebooted
NOTHING was functioning, voice was erroring, car location was skipping and moving me while not in motion and NO audio could be heard.
Disconnection of the batt and another reboot fixed it
so powering it off will mess with it.....possibly
Type X is offline   Reply With Quote
Old 09-08-2006, 10:37 AM   #11 (permalink)
djdefcon's Avatar
Thanks guys....Ill try diming my speedo later when i leave work
Old 10-18-2006, 10:04 AM   #12 (permalink)
Nacho Cheese!
letsgoflyers81's Avatar
I noticed the same problem last night and couldn't figure out what I was doing wrong. I'll run out during lunch to try turning down the brightness and see if that does it.
letsgoflyers81 is offline   Reply With Quote
Old 10-18-2006, 12:13 PM   #13 (permalink)
bluegt2k's Avatar
FG Squad #135
I have that same issue, tonight i'm going to give the dimmer a try
bluegt2k is offline   Reply With Quote
Old 10-18-2006, 11:39 PM   #14 (permalink)
slimfit's Avatar
all you have to do is hold the + button until it beeps. this is full bright mode, then hold the - button until it beeps. when you do this the nav will go between day and night mode when you turn your headlights on and off. make sure to do all of this while your headlights are on.
slimfit is offline   Reply With Quote
One-Touch Feature on Moonroof Quit Working Silver8th Mechanical Problems & Technical Chat 12 05-23-2006 05:41 PM
