For those grinding 2nd...
I finally found out the problem with my shit... @ first I thought it was the tranny going, but then I was like naw, it only grinds @ high rpm shifts... So then I remembered that the clutch pedal is adjustable.. I guess honda's default setting doesnt disengage the clutch all the way, so it wears out the clutch and soon you'll be grinding 2nd during those high rpm shift...So I just adjusted the nut and brought the engagement a bit higher... NO MORE GRINDING FOR ME!!! Ill try to post pics later on..
#4 (permalink) | |
Add me to that list as well. Alternatly if you can lower the brake thatd work for me as well. |
#6 (permalink) | |
#7 (permalink) | |
#10 (permalink) |
![]() Join Date: May 2006
J. M. back by popular demand!
Nice find! +1
![]() Visit my city! Free vagin for every resident (in direct contrast to the other cities that only provide free Fleshlites!) http://eat-mykhram.myminicity.com/ |
#12 (permalink) |
The clutch is hydraulic, and is self adjusting. if you raised the pedal your just moving the point at which it dissingadges. If the pedal was 6" from the floor, and now its 4" from the floor. You just moved the point at which it dissingadges. While speed shifting you would not have to push the pedal as far as you would have before. there for you now engage the clutch all the way were you werent before.
hopefully this doesnt mean that the clutch is wearing prematurly. There has been a couple of post with clutches going bad already. Lets hope not. I did not spend the extra money on an si to get a cheap clutch. |
#13 (permalink) | |
#15 (permalink) | |
#16 (permalink) |
If you push the pedal the same now as you did before. Your getting more engagment.(after adjustment) Im just saying that it sounds suspecioucs. That means you had to push the pedal farther, to do the same job. With all the post Ive seen the last couple of days about second gear grind, And not shifting properly. I hope some more poeple try this fix. If alot of people find that this helps, there might be alot of clutches being replaced in the future. Im not saying im 100% right. but its something to keep an eye on.
#19 (permalink) |
This might be the thread I've been looking for forever... Cuz I swear that it always feels like my clutch never fully disengages and gets popped out when im shifting from 1-2 or 2-3 (more so on the 1-2 shift).... lately i've already been sketching out cuz my clutch has been making weird noises... maybe it's due to wear because the clutch pedal never fully disengages? It sounds like a squealing almost like dusty or worn brakes when im trying to start first gear.....anyway i'm gonna be taking into to honda to see wtf is up. Thanks for the insight.
| Has anyone takin their SI back to dealer for a notchy feeling 2nd gear yet? | 06redsi | Mechanical Problems & Technical Chat | 11 | 10-02-2007 03:37 AM |
| Rev Matching/Gear Grinding | CaliGuy | Garage | 46 | 08-31-2007 07:13 PM |
| 2nd Gear.... | leenangle | Civic Coupe And Sedan | 27 | 08-22-2006 10:22 PM |
| 9-11 pentagon video - feedback on "loose change 2nd edition" | tehLOLbbq | Water Cooler | 4 | 07-14-2006 01:37 PM |
| Tried to shift to 2nd, grinded really bad! | Only a R18 | Civic Coupe And Sedan | 14 | 06-22-2006 07:51 AM |
