Jonny Blaze
Cel p2a00, p1172 help needed!!!
okay i got two cels last week a P2A00 and a P1172
I did a search and i found these results TSB Engine Controls - MIL ON/DTC P1172 or P2A00 Set problem with Air/Fuel Sensor The air/fuel sensor is damaged by moisture in the exhaust system during engine warm up. my engine mods are Vibrant header w/HFC 12inch resonator Vibrant cat back, injen CAI, P2R spacer.(if it matters) i have a JDM valve cover also after reading up on it it seems like if i replace the sensor(is this the o2 sensor?) it will fix it. Should i take it to honda, or do it my self? after getting this fixed is it going to happen again? Is this because of my mods or because of a honda defect? Thanks Jon |
![]() Join Date: Nov 2005
First, yes, you might need to replace your O2 sensor.
And you might just need to check the connections. Which is it? Please include in your modding budget shop manuals for your car. Follow the diagnostics. Then decide. Else, bring it in to Honda. -mr. bill |
Jonny Blaze
i reset the battery and it didnt come up for a few days until i hit vtec lol. and i cant clear them with my Scan Gauge i have to reset the battery. I will check the connections hopefully tomorrow.
#6 (permalink) | |
Nate
Jonny Blaze
its not a MAF code i thought it was a O2 sensor code. look at the link i posted in the first page. i ordered a angled defoiler hopefully that fixes the problem i will post results when i get everything set up
#10 (permalink) |
Michael
I just had the same problem. I also have a vibrant RH with HFC. . .
From what I understood it was the first sensor and not the second, so a defouler shouldn't help as those go on the second sensor. I'm kind of in the same predicament though as to whether I should take it to Honda or not. |
#11 (permalink) |
Brian
i talked to a mechanic...he said the only way to fix the issue is to replace the sensor and clear the code....no defouler will work for this code. also, he did say that replacing it does not stop it from failing again from the same issue(whatever it may be...im thinking design flaw as we are all vibrant header owners but thats just a guess).....i dont mind dealing with the light but i know it has affected my gas milage as the car is now running rich( and the trip meter says so). also it could cause engine damage if left unresolved for an extended period of time. I would take mine to honda but as soon as they see the header everyone knows they are not going to touch anything on the exhaust system
#13 (permalink) |
Brian
that tsb might help the people that have a stock exhaust system but when they see an aftermarket exhaust header they are not going to fix any sensor in that system
#14 (permalink) |
Eman
i have these codes p1172, p0135, p0141 on my swapped 06 lx k20z3.. with si stock exhaust & cai. i replaced the o2 sensor and nothing happened. i've been dealing with this issue for the pass 5 months. I also upgraded the ground wires and nothing has changed. I read on mitchell and it stated to check the connections, replace o2 sensors & if not to replace ecu.... I have not replaced the ecu yet.... but my mileage is definitely being affected 260.
#17 (permalink) |
Brian
im going to the dealership today.....thanks for asking though. i cant wait to here there rediculous explaination of why they won't warranty the repair(they havent said so yet, but im pretty sure they will not fix it for free). im mainly going up there to check to see if my software is current and get a price on the part.......ill keep you posted
#18 (permalink) |
Dave
they will not fix it for free you have a header. the header is causing all your problems, it's probably a piss poor design cause if you read the tsb it talks about moisture damaging the afr sensor during warm up. the location of the sensor bung is probably in a place where it is even more prone to moisture build up. so your options are, put your original exhaust manifold back on. plug up the bung on the header, drill out a new hole in a better spot and weld a new bung on, but keep in mind you can't just put it anywhere on there.
#19 (permalink) |
Michael
So I talked to my dealership earlier today. They said they'd replace the O2 sensor under a "goodwill" warranty. I'm sure they weren't supposed to but it was definitely a nice thing to do.
They weren't so generous at first though. I had talked to them earlier, asking what would happen if it wasn't covered under warranty, and whether they thought it would be covered. I also supplied them with the info of the exact code that was being thrown and the fact that I DID have an aftermarket header and also that I had cleared it before and it came back within a day or 2. They said it would be $82 in diagnostics if it wasn't under warranty, but they weren't sure if it would be covered or not. They called back 2 hours later, saying that it was a P2A00 code, that they cleared the code and it didn't come back so they saw no problem, and that it wasn't covered under warranty due to an aftermarket header... ![]() 20 minutes of arguing later I got the diagnostic fee waived since it was the exact information I had supplied them with in the first place. They told me if the light came back then to call them again and they'd figure something out. 5 miles down the road the light came back on and I dropped it back off the next day. |
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/129620-cel-p2a00-p1172-help-needed.html
| Thread Cel p2a00, p1172 help needed!!! - 8th Generation Honda Civic Forum | 8th Generation Honda Civic Forum | BoardReader | This thread | Refback | 09-19-2011 05:09 AM | |
| P2a00 | sunnydude98 | Mechanical Problems & Technical Chat | 1 | 02-11-2009 09:37 PM |
| just what i needed | xztheericzx | Introduction & Pictures | 9 | 11-04-2007 10:39 PM |
| TSB Engine Controls - MIL ON/DTC P1172 or P2A00 Set | iknowmysh1t | Mechanical Problems & Technical Chat | 0 | 06-29-2007 01:36 AM |
| Civic Coupe EX and SI owners Help Needed!! connectors needed!! | PugManTerror | I.C.E., Electrical, Security, & Navigation | 10 | 12-10-2006 08:44 PM |
