Old 11-18-2008, 12:12 PM   #1 (permalink)
Strange Humming Sound
Hi folks. I tried searching but couldn't find anything similar. I have an 07 EX Coupe AT. As its started to get colder, it's starting to make this strange humming sound. I'll try to explain, but it's weird. It only happens in the morning when its cold out ( < 35). When I put the key in the ignition and turn to where the radio and stuff comes on, there's this humming noise that seems to be coming from somewhere behind the little cubby hole underneath the HVAC controls. It's relatively loud (can be heard with radio on). It sounds almost like an electric motor dying, if that makes any sense. The sound continues after starting the engine, but stops after a minute or two. Almost as if it's "warming" up. Then, it won't happen for the rest of the day. If its not cold in the morning, no noise. Any thoughts?
tjaikens is offline   Reply With Quote
Old 11-18-2008, 12:18 PM   #2 (permalink)
HondaFREAK's Avatar
I don't think you should be worried about it. If the car drives fine, and it's only when it's cold I think that it's a normal response to the weather. There are a number of things that could be causing it, but if it's like you said it may just have something to do with the fuel pump and the weather.
HondaFREAK is offline   Reply With Quote
Old 11-19-2008, 08:13 AM   #3 (permalink)
This morning I figured out it's coming directly from the navi unit. Isn't there a fan in there? If there is, that would make sense. I'm thinking that's causing the sound. The car's still under warranty, so I guess I'll be giving my local honda dealer a call.
Old 11-19-2008, 10:20 AM   #4 (permalink)
HondaFREAK's Avatar
there might be a fan, but it could be the DVD drive for your Navigation Maps spinning or warming up
Old 11-19-2008, 10:30 AM   #5 (permalink)
That's what I thought at first, but after removing both the DVD and the audio CD, the sound continues.
Old 11-19-2008, 11:13 AM   #6 (permalink)
wannabfast's Avatar
Thai
the navi unit does have a fan in the back... could take it all apart and blow it out with some compressed air... might have some dust collecting in there
wannabfast is offline   Reply With Quote
Old 11-19-2008, 04:32 PM   #7 (permalink)
Careful not to spin the fan with the compressed air. You'll wreck the bearings and have more noise than you do now! Keep the fan stationary and blow it out. Or better yet, take it in for warranty.
killsw1tch is offline   Reply With Quote
Strange liquidy/slushy sound intoflatlines Mechanical Problems & Technical Chat 7 10-10-2008 02:06 PM
Strange whoosh sound coming from car!? zemoffm Mechanical Problems & Technical Chat 4 08-08-2008 12:13 PM
strange sound when hitting v-tech roadcarver Civic SI 15 11-03-2007 04:33 PM
HID Ballast Humming ensoniq Lighting, H.I.D.'s, & Neon 8 05-03-2007 07:09 PM
Strange humming sound? chylld Mechanical Problems & Technical Chat 21 10-02-2006 02:03 AM
