Old 08-14-2006, 01:54 AM   #1 (permalink)
Junta's Avatar
Exclamation Requesting help in removing a bolt with stripped threads
Hi guys,
I ran into a little problem over the weekend when trying to install fog lights into my Civic. During the reinstallation of the bumper, I accidentally used the bolt that goes from underneath the car, that holds the splash guard, in the spot where the front grill meets the front bar. Upon doing so, I also stripped the threading of the hole, and now the bolt is stuck. I've tried pulling and turning in hopes that the bolt will catch on some thread, but there has been no success. I've also tried the brute force method of just yanking the bolt out, but that has been unsucessful too. Now I'm stuck with a bolt in the wrong place, and my front bumper is not tightly secured.
My question is, is there any methods of removing the bolt while trying to keep everything intact?
I'm extremely disappointed in my stupidity.
Any help would be greatly appreciated.
Junta is offline   Reply With Quote
Old 08-14-2006, 02:36 AM   #2 (permalink)
CaliGuy's Avatar
J. M. back by popular demand!
easy out bit?
Old 08-14-2006, 09:29 AM   #3 (permalink)
If you can get a flat screwdriver behind the head of the bolt you may be able to pry back on it a little while trying to remove it.
RITDR is offline   Reply With Quote
Old 08-14-2006, 10:15 AM   #4 (permalink)
n00b retro whore
ethlar's Avatar
very carefully drill out the middle of the bolt perhaps?
im not sure how to get the bolt out, but i do know you probably will have to retap the hole once its out.
Old 08-14-2006, 12:37 PM   #5 (permalink)
Junta's Avatar
Thanks guys. I tried prying out the bolt with a screwdriver and pulling and turning simultaneously, but still no luck. I think I was more afraid of bending the screwdriver shaft. I'll try again with a bigger sized screwdriver perhaps.
If all fails, the best solution is to take it to the dealership probably...
Old 08-14-2006, 12:54 PM   #6 (permalink)
Photobucket
Silver8th's Avatar
EARL
If the the bolt is sticking out maybe a set of Vise Grips will help.
Old 08-15-2006, 11:59 PM   #7 (permalink)
Junta's Avatar
Alright, so I decided to take the advice of the members here and the Honda mechanic who also told me to try the screwdriver method. I took a screwdriver with a thick enough shaft, and proceeded to pry and crank with the wrench. After several cranks, the bolt comes flying off, and for a moment, I thought I had succeeded. However, upon closer inspection and to my dismay it turns out I snapped the bolt in half and left the threaded end still stuck in the hole. Oh fluck, now I'm screwed.
Any suggestions short of going to the mechanic now?
Old 08-16-2006, 12:27 AM   #8 (permalink)
dobiejoe's Avatar
Joe
go to sears and get a 50 dollar specialty extracter set. Thats what you needed in the first place.
dobiejoe is offline   Reply With Quote
Old 08-16-2006, 01:00 AM   #9 (permalink)
CaliGuy's Avatar
Get an easy out, as I suggested. It's a drill bit that digs into the bolt and once in you just reverse the drill and it comes right out...well, in theory. In truth they are a bitch to use, but they do work...
Right tool for the right job! Do as I say, not as I do...lol
Old 08-16-2006, 01:04 AM   #10 (permalink)
radiocontrolhead's Avatar
Danny
i want to knwo, why didnt' u take notes as to what bolt goes wehre? that is RULE NUMBER ONE!
Old 08-16-2006, 01:12 AM   #11 (permalink)
peliROJO's Avatar
"my mind playing tricks on me" - Geto Boys
http://www.youtube.com/watch?v=nnRS-3AyGUs - NSFW :)
peliROJO is offline   Reply With Quote
Old 08-16-2006, 01:26 AM   #12 (permalink)
CaliGuy's Avatar
The Geto Boys are awsome! I have their greatest hits CD, which also has the DVD with their videos...good stuff man..
OK back to topic
Old 08-16-2006, 11:11 AM   #13 (permalink)
Junta's Avatar
As I mentioned in the first post...I was extrememly disappointed in my stupidity
RULE NUMBER TWO: Don't be greedy when tightening any screw or bolt. Once it's snug, it's good.
Old 08-16-2006, 03:34 PM   #14 (permalink)
06CivEXJon's Avatar
Jon
Yeah dont ever overtighten bolts,nuts or screws. I learned my lession after i stripped a bolt before.
Old 08-17-2006, 05:42 AM   #15 (permalink)
I would try a combination of heating the thread housing of your bumper and spraying generous amounts of WD-40 into the contact area. You can use a hair dryer to do the heating; do NOT heat the bolt itself!
That's if you want to be anal. If you could somehow get your hands on a pneumatic drill, you could solve your problem in 0.22 seconds. Either way, I think that your bumper's thread will be stripped... your dealer will probably have to install new mounts, or possibly replace your bumper. Of course, you could bootleg the mounts and fabricate some kind of clamp!
Good luck!
televascular is offline   Reply With Quote
