What does it mean when your car can only shift gears when the car is off, but when its on, it wont go into any gear?
I may be able to get it into reverse, but its grinding like crap! Its even letting me do it when my foot is not even pressing the clutch pedal! What the heck is going on!?
Another vote for clutch problem. You must have toasted it good.
If you can shift if your car is turned off that's normal. Since the flywheel isn't spinning and no clutch is needed to shift. But once you turn on the car things start spinning and you have nothing to stop that spin if your clutch isn't working. So it probably isn't the tranny but the clutch. |
#11 (permalink) |
Its actually on my CRX. It is a cable transmisson.
See what happened was, I was driving home from work one day, then right in the middle of me shifting into second gear the clutch cable broke. I then pulled it out of gear without using the clutch pedal, because I didnt have the abilty to do so when the cable broke. So that weekend I went and got an 06 EX Coupe with Navi to make my self feel better, towed the CRX home and forgot about it for three months! Now I want to drive it again! The clutch was in great shape right before the cable broke, so I just replaced the cable. The clutch never slipped or anything before the cable broke. I wonder if the sychronos got jacked up when the cable broke between shifts?
#14 (permalink) | |
Recheck your work. Good Luck! |
#16 (permalink) | |
Unhook the cable and test the movement of the clutch fork. If it is loose then it came off of it's pivot point and may need to be pushed back in. Try to wiggle it up and down. Try to push it upward until it locks into position. Then reattach the clutch cable and see if that takes care of the problem. |
#17 (permalink) | |
![]() Join Date: May 2006
J. M. back by popular demand!
![]() Visit my city! Free vagin for every resident (in direct contrast to the other cities that only provide free Fleshlites!) http://eat-mykhram.myminicity.com/ |
#18 (permalink) | |
I think I should give up and just put a K20 in it! |
| Too Early for Tranny Flush?? | taste | Do It Yourself Articles | 12 | 06-23-2006 08:55 PM |
| Which is better | gimmedat2640 | Garage | 18 | 06-07-2006 09:46 AM |
| Honda Begins Production at Georgia Transmission Plant | webby | Honda Industry News | 2 | 05-19-2006 03:37 PM |
| Transmission Question | RockALittle250 | Garage | 4 | 04-28-2006 04:55 PM |
| Found out today my transmission is probably going to be replaced. | enter801 | Mechanical Problems & Technical Chat | 25 | 04-04-2006 09:49 AM |
