Old 08-11-2006, 06:55 PM   #1 (permalink)
a question about skunk2 shift knob...
Hey guys!
Questions here about installing the skunk2 shift knob. Sorry if I posted the post in the wrong session!
Do I have to use the little metal nut under the knob? It appears to be lower without the nut so I was thinking just put the knob on without the nut...
Also, after I installed the knob. The diagram that shows all the gears and stuff was not facing straight. How do you guys fix that? I've already screwed it as tight as it could be...
Any replies would be very much appreciated!
-Chris
oda11 is offline   Reply With Quote
Old 08-11-2006, 07:03 PM   #2 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
The answers to your question:
1) Use the nut already on the Si shift knob. The one included with the shift knob won't fit.
2) If the diagram is not aligned, use force and align it properly. You think you may have twisted it all the way, but trust me, you can go more. I did it. Don't worry, you aren't doing any damage. You are just going to break some new treads.
Old 08-11-2006, 07:08 PM   #3 (permalink)
Thanks Yodums!
1) Can I just not use the nut at all?
2) You mean just twist the knob more? It's really slippery (Did I spell that right? ) though...
Old 08-11-2006, 07:24 PM   #4 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
1) Sorry, I misread your original post. Yes, you can not use a nut. But like you said, it will just sit low.
2) Wash your hands and give it a try. That or use something to grip it like a piece of rubber.
Old 08-11-2006, 07:49 PM   #5 (permalink)
could ya take pics after ur done installing it man? i wanna see how it looks.
kurdtkobain87 is offline   Reply With Quote
Old 08-11-2006, 08:49 PM   #6 (permalink)
ok :)
Old 08-11-2006, 08:50 PM   #7 (permalink)
thanks again man, but i tried twisting it REALLY REALLY REALLY hard, but still couldn't get it straight....
Old 08-12-2006, 01:48 AM   #8 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
How badly aligned is it?
Old 08-12-2006, 02:01 AM   #9 (permalink)
uhm, the diagram is like... 30 degrees off, lol
if i put the nut on, it's the same degrees but face the other way...
Old 08-12-2006, 02:15 AM   #10 (permalink)
HAQER's Avatar
Just screw it down as low as it will go with the diagram straight and then screw that nut up to meet the shift knob. Thats what I did and it worked great.
HAQER is offline   Reply With Quote
Old 08-12-2006, 02:31 AM   #11 (permalink)
ohhhhh............ WOW, NEVER thought about that, lol, thanks!
eh, i guess ill have to use the nut...
Old 08-15-2006, 01:39 AM   #12 (permalink)
are you installing on an SI or regular Coupe?
Does the regular coupe's nut work the same way and fit right?
chickennoodles is offline   Reply With Quote
Old 08-15-2006, 03:51 AM   #13 (permalink)
its an Si
uhm... about the regular coupe's nut, i am not sure but i suppose they have diff. nuts?
Old 08-15-2006, 04:34 AM   #14 (permalink)
Originally Posted by oda11
its an Si
thanks, anybody know?
Old 08-15-2006, 04:44 AM   #15 (permalink)
Supreme Pizza!
Izzy's Avatar
Pretty sure they're the same.
Old 08-15-2006, 04:48 AM   #16 (permalink)
if they are the same, how come i read on another posting that i need to find another nut?
Old 08-15-2006, 12:36 PM   #17 (permalink)
Supreme Pizza!
Izzy's Avatar
The locking nut that Skunk2 supplies is notoriously stupid. It's too small to fit the thread of the shifter stalk. So, if you have an FG2, you use the original locking nut with the shift knob. If you have the Coupe or Sedan, either buy a simple nut at Lowe's, or get someone's FG2 nut. :)
Old 08-15-2006, 07:07 PM   #18 (permalink)
thanks alot izzy, so in other words, the coupe's nut will not be compatible with Skunk2 at all? I have no idea where i can find a similar nut here in Canada
Old 08-15-2006, 08:57 PM   #19 (permalink)
Supreme Pizza!
Izzy's Avatar
Hardware store. :) Anyway, if you can take a pic of the coupe's nuts (hahaha) then I can answer. However, I was under the impression that the coupe did not have one, unless you sprung for the sport shifter.
Old 08-15-2006, 09:09 PM   #20 (permalink)
coupe's nuts, LOL
isn't the nut under the knob?
I'm not even sure how to take the knob off now
when I'm twisting counter clock wise, the boot twists with it as well
Am I doing something wrong?
question on A/T shift knob? wolfxkc Civic Coupe And Sedan 8 05-28-2008 02:00 AM
Shift knob eric3621 Mechanical Problems & Technical Chat 4 07-08-2006 03:34 PM
Shift Knob Question idono1301 Inside and Out 1 06-28-2006 03:08 AM
Help: Compability between 7thgen and 8thgen shift knob? _karu_ Do It Yourself Articles 3 04-11-2006 01:59 AM
