Old 08-09-2006, 09:45 AM   #1 (permalink)
GeorgiaBoy's Avatar
Cool Weird Smell when MAX A/C is on
Anyone have a weird smell coming from the A/C after the Car has been running for awhile? Not really a bad smell, just a weird odor.
GeorgiaBoy is offline   Reply With Quote
Old 08-09-2006, 09:57 AM   #2 (permalink)
Retread's Avatar
It re circulates the cabin air on max. Wash your feet. Or stinky tennis shoes maybe ?
I have no such odor when the A/C is set to max.
Retread is offline   Reply With Quote
Old 08-09-2006, 10:11 AM   #3 (permalink)
FujiBlueSi's Avatar
Tim
Originally Posted by GeorgiaBoy
Anyone have a wierd smell coming from the A/C after the Car has been running for awhile? Not really a bad smell, just a wierd odor.
Yeah, I get the smell too. It's not unpleasant, just strange. It goes away after a few mins. My wife's 03 EX has the same smell.
FujiBlueSi is offline   Reply With Quote
Old 08-09-2006, 10:20 AM   #4 (permalink)
CameronJr9's Avatar
Back and Forth Forever
Can you describe the smell?
Old 08-09-2006, 10:30 AM   #5 (permalink)
FujiBlueSi's Avatar
Tim
Hmmm....smells like chemicals. Freon maybe? (R134) Hard to describe since I haven't smelled anything else like it to compare it to. It doesn't happen all the time. It only really happens when I first put the AC on max and the engine is under load. It goes away quickly though and the AC works great.
Old 08-09-2006, 10:33 AM   #6 (permalink)
Is it a sweet smell? That's usually antifreeze which may mean a leaky heater core, but with a brand new car, I doubt it.
tegrady is offline   Reply With Quote
Old 08-09-2006, 10:37 AM   #7 (permalink)
FujiBlueSi's Avatar
Tim
Definitely not antifreeze. Doesn't smell sweet. I guess the smell of R134 is the best I can compare it to. I used to sell it so I smelled it quite a few times when the cans were defective.
Since it happens so infrequently I have just ignored it. I haven't smelled it in a few weeks and I had the AC on max all last week cuz of the 100+ degree weather we had here.
Old 08-09-2006, 12:14 PM   #8 (permalink)
PoLiShPrInCe's Avatar
i have the same smell... i actually thought that it might be mildew so i bought this stuff which your spray in the vents.... then it went away for awhile but returned.. not as harsh
PoLiShPrInCe is offline   Reply With Quote
Old 08-09-2006, 12:25 PM   #9 (permalink)
tomasro's Avatar
Turner
If you run the A/C for a long time, and you don't air out the system once in a while, the smell is mold/mildew building up in your system. Make sure if you run your A/C a long time to turn off the a/c and run the air at full blast until all the coldness goes away (takes a minute). Otherwise, you'll build up such mold/mildew in your cooling system that you'll never get rid of that smell...
My parents had to have their entire cooling system removed and cleaned to get theirs to go away because they didn't know this. It applies to all vehicles with A/C.
tomasro is offline   Reply With Quote
Old 08-09-2006, 12:35 PM   #10 (permalink)
CivicWithNav's Avatar
use MAX AC(recirc air) only for short period of time
it has been known to cause Bad smell, nausia, headache and such...
when i go on the highway i vent the roof and put a/c fresh mode in low fan...the pressure pushes air into the cabin anyway
Old 08-09-2006, 01:12 PM   #11 (permalink)
FujiBlueSi's Avatar
Tim
Nice tips. I will try it out. Thanks.
Old 08-09-2006, 01:18 PM   #12 (permalink)
Photobucket
Silver8th's Avatar
EARL
.....moved to Mechanical problems/Vehicle Issues Forum
Old 08-09-2006, 01:24 PM   #13 (permalink)
RedSIinPA's Avatar
I do notice a smell and I do think it's sort of a air/freshener sweet smell. It's not a great smell, not a bad smell - just a smell. I'm not sure what's causing it in mine but given the weather around here as of late, I was running Max AC almost all the time. I'll try to run my fresh air a/c today and then blow just the fan as I approach home.
RedSIinPA is offline   Reply With Quote
Old 08-09-2006, 01:41 PM   #14 (permalink)
spunkin82's Avatar
thanks for the info, i was experiencing the same thing when i have the air circulation on for a long time... i just turn it off when the smell comes out.. but i dont really use the air circulation unless it's really hot outside and the AC feels really weak. Thanks again.. at least i know that my car doesnt need any service.
spunkin82 is offline   Reply With Quote
Old 08-09-2006, 04:16 PM   #15 (permalink)
Well it depends on how you drive. The way Honda's A/C works, is that the clutch disengages when you either go past a certain rpm, or floor the gas. Either way your A/C basically turns off, but your fans don't, and there's that smell for a lil while. It seems normal on most cars, if you keep the fans on with the windows open, it'll go away in a minute or two. Or just keep the A/C on.
Old 08-09-2006, 06:01 PM   #16 (permalink)
10Hondas's Avatar
Mine has done it since day one. It is a chemical smell and it only does it with the AC and recirc on. It goes away as soon as I turn off the recirc.
10Hondas is offline   Reply With Quote
Old 08-09-2006, 07:07 PM   #17 (permalink)
BigBucksT's Avatar
It is mold from when the freezing element of the a/c is left on for long periods of time. This is why every time you turn your car off, make sure the a/c is off. Otherwise, you get this nasty moldy smell.
BigBucksT is offline   Reply With Quote
Old 08-09-2006, 07:34 PM   #18 (permalink)
10Hondas's Avatar
My problem definately was not mold, it was a defenite chemical smell. My wife's CRV had a mold problem in the ac sys, and it was a different smell.
Old 08-09-2006, 09:16 PM   #19 (permalink)
VICHONDAEX's Avatar
This is for real. maybe it's a death rat inside under your back seat..If you leave the car outside maybe you are anotehr victim of a rat attack,,,
VICHONDAEX is offline   Reply With Quote
Old 08-10-2006, 10:19 AM   #20 (permalink)
GeorgiaBoy's Avatar
Cool The Smell
I am a Heating and Air tech by trade in the civilian world and this is definitly not mold. It takes a couple of months for skin cells to start a mold process. I was thinking that it could be related to the cabin filter or the evaporator not clearing the drain fast enough. It does happen way to oftne than it should and it should work properly. I have an appointment Monday for the reflash and will have it looked at then. I will follow up on their findings.
Anybody else think their A/C is weak? fake Mechanical Problems & Technical Chat 135 09-03-2007 06:50 AM
How Much Horsepower Do You Think The A/C Takes From Your Engine civicboy Mechanical Problems & Technical Chat 21 08-09-2007 10:35 PM
Rattle from dash with Max A/C setting GalaxyGreySi Mechanical Problems & Technical Chat 3 05-28-2006 03:39 PM
Finally Got A/C Kit For DX Civic civicboy Mechanical Problems & Technical Chat 6 04-06-2006 01:03 AM
Wierd fumes and buning smell in Si... GeorgiaBoy Driving Experience 9 01-17-2006 11:00 PM
