Well I was cleaning my engine bay, just wiping stuff off and what not. I wanted to get under Intake Manifold and i was taking off the nuts to take it off, and I didn't realize that you only had to take off two bolts.
Getting to the point, putting back the cover and the other three bolts i managed to break the bolt holding on the valve cover?... Is it safe to drive with this off, and what do I have to do to fix it? Complicated?
#15 (permalink) |
Firm approval....I haz it
Under that metal cap there is a rubber grommet that seals the valve cover so oil does not come out of there. Not exactly sure how violently the oil moves inside there but I wouldn't drive the car as is.
Try to remove the metal cap only and try to bolt the acorn nut onto the snapped bolt so you may get a good seal. If you drive around as-is it might vibrate off and fall while you drive. In order to remove the snapped head bolt you have to remove the valve cover and and use a long tube socket to remove. I believe a 12mm. Once you remove the snapped bolt place a new one in and torque to spec and reassemble the valve cover. This is what it looks like once the VC is off.... ![]() This is just like the bolt you snapped bu in a different spot on the head...
#19 (permalink) |
Run down to Sears and buy a Grabit set...it'll make it easy to get the bolt out.
One side of the Grabit bit drills a starter slot into the remnants of the old bolt...then you flip it and it backs the bolt out nice. Worth the ~$30...you'll use it for more than just this anyway. |
| timing chain snaped? 98 frontier | 4door | Garage | 11 | 10-09-2008 10:37 PM |
| my best bolt on.. yet | 4door | Water Cooler | 29 | 10-09-2008 01:10 PM |
| bolt ons | 06hypecivic | Garage | 7 | 05-23-2008 11:05 AM |
| Which bolt ons | Tomoyuki | Bolt-Ons And All-Motor | 2 | 12-27-2006 06:25 PM |
| bolt-ons | junsu | Civic SI | 1 | 11-16-2006 01:30 PM |
