slow steering after upgrade to 215/45/17 tires
Hi all,
I have just upgraded my tires and wheels from 195/65/15 - 15 x 6 to 215/45/17 - 17 x 7. What I have noticed is that whereas the steering was very sensitive before, it's now very "slow" to respond. Is this because of the wider contact patch on the road? Changing tire pressure to compensate hasn't made any noticeable difference. I'm running kumho kh11's at the moment. What's the easiest way to restore the steering response (new tires or wheel alignment)? Thanks. |
with the wider tires, you should have felt that you more grip.. if you take turns a lil faster, your tires wont schreech. but you would encounter a tiny bit of a harsher ride. a 45 ride profile isnt bad, just dont go below that, then you may damage the wheel if you hit bumps or pot holes. hope that helped.. it also depends mainly on the tire itself, the kumo it the lowest tire in its class? what is the speeed rating on the tire?
wheel algiment would only help with steering virbration.. but yes it is def recomended to do the wheel aligment. |
Thanks for all your replies. I've just driven the car again and it seems that the steering is heavier, rather than slower to turn in. (Yes, the car is definitely more grippy) I'll just get used to it. Next time, I'll look for a another brand of tire to see if there is any difference.
The tire/wheel package you've moved to presents a lot different profile to the road. A narrow 65-series tire is much more rounded at the edges and acts that much narrower as the effective contact patch is a lower percentage of its (lesser) total width than your new size. And new tires tend to feel light in the steering for this reason--they still have some profiling left to them at the edges of the tire.
Tire makers profile tires carefully to optimize their steeing feel and noise characteristics. As you wear a tire flat, you lose the benefit of this and the steering feels heavier and noise increases. When a tire maker lays some marketing buzzword on you like 'uni-Q technology' or some crap like that they are often just referring to whatever profiling techniques they employ at the moment--as if other makers don't... This is usually pretty obvious when you replace a set of tires with a new set of the same design. It's amazing how much more civilized the new set feels. Unfortunately, this sensation is gone all too soon as the road wears the tire ever-flatter across the width of the contact patch (amongst other changes). |
#10 (permalink) |
the contact patch is gonna be the same for the same PSI. the only way to reduce the size of the contact patch is to lighten the load on the tire or increase the PSI.
i think the grip of the tread design has more to do with it personally. at first i thought maybe that the new tires that are not broken in were not gripping thus needed more steering input. but as you clarified this was not the case.. Last edited by e60.deluxe; 10-11-2008 at 08:32 PM. |
#11 (permalink) | |
As far as old vs. new, compare the shoulders of a worn-out tire to a brand-new replacement and the difference is visually obvious. If there is sufficient sidewall stability the edge of the used tire will be sharper, rather than the comparitively rounded shoulder of the new tire. And low profile tires inherently have more sidewall stability, allowing them to more effectively flatten the contact patch and sharpen its edge with wear. Last edited by ray; 10-11-2008 at 09:06 PM. |
#12 (permalink) | |
in anycase, i know all that, but the point is, i dont see how, when turning the wheel, a wider contact patch would resist more than a narrower one. when we say wider, its really still an elongated shape, but a wider tire makes it less elongated and more square shaped. a wider one would provide more lateral grip, but we are not talking about lateral grip. i dont see how it could HINDER pivoting. i would think that being more square shaped would, if anything, HELP pivoting, and the increase in lateral grip would HELP the car change direction quicker. Last edited by e60.deluxe; 10-11-2008 at 09:13 PM. |
#13 (permalink) |
The thing you're missing is the fundamental way a four-wheeled vehicle turns--and the role of caster in it. Just turning the wheels one direction or another will not affect turning of the vehicle. It will 'push like a dump truck', as circle track boys say. You have to tilt the front wheels in order to jack weight, allowing the load to be lifted from the inside rear wheel. The wider the tire, the wider the patch, and the longer the 'arm' formed by the width of the tire outside the pivot axis of the front tire. This magnifies the weight-jacking affect of the castor of the steering, jacking more weight and thus affecting more turning of the vehicle per degree of steering wheel travel, thus feeling heavier as you turn that wheel. Moving the front wheels out towards the fender lips (like a 25mm wheel offset) has the same effect, although to a greater degree.
And such, it's the same case on both points. The area matters not, it's the geometry of the entire system. You can't simplify the geometry of the contact patch down to area, because the area isn't involved in this phenomenon. It's the change in width, translating into a change in weight-jacking, translating into a change in feel and effort at the steering wheel. You further lessen the weight-jacking effect by using a tire with a more rounded edge (higher profile). The edge is not as effectively forced into the ground by the castor of the steering, posing less resistance to the turn of the steering wheel. |
#14 (permalink) |
More than likely, your slower turn in is caused by a change in wheel offset when you went to the 17's. This changed your scrub radius, which in turn effected your turn in. I know this means nothing to most people who don't have experience with suspension setup on race cars, so rather than try to explain the scrub triangle and its effects, if you are interested, google "ackerman angle, steering axis inclination, and scrub radius" and read up. Otherwise, just know its probably your wheel offset that is effecting your turn in most.
Hans Last edited by HsOffRoad; 10-13-2008 at 06:20 PM. |
| WHats the Best Size Tire for the Best Ride? 215/45/17 - 225/45/17? or 215/50/17 ? | coach2fast | Wheel And Tire Upgrades | 5 | 05-14-2008 12:10 PM |
| post your 215 45 17 tires with.... | honda_man12 | Wheel And Tire Upgrades | 0 | 06-06-2007 11:35 PM |
