Old 10-10-2008, 09:23 AM   #1 (permalink)
Blacklespaul's Avatar
HELP, cant compress rear si caliper
Trying to change rear pads, For some reason the freakin rear brake caliper won't compress, its the parking brake side but I disconected the cable,still won't budge with my chanel locks, had no problem with the front pads...wtf??!
Any help would be sooooo appreciated.
Frustrated in jersey...
Blacklespaul is offline   Reply With Quote
Old 10-10-2008, 09:32 AM   #2 (permalink)
I haven't changed the brakes on my Civic (its new!) but on my Eclipse I would open the brake fluid reservoir a little bit, and that would relieve some of the pressure. Just be careful not to spill any out.
RR-Si08 is offline   Reply With Quote
Old 10-10-2008, 09:40 AM   #3 (permalink)
johnbud's Avatar
JOHN B.
i work at ford and on the small cars with rear disc i have to use a special tool to push them in.. the piston inside the caliper has to turn while applying pressure to turn in clockwise or counter clockwise deppending witch side... don't know if honda's the same.. whatever you do don't open and brake lines.. could cause air to get into the brake system then it will be a major pain in the ass to bleed everything out... don't know if i helped any..
johnbud is offline   Reply With Quote
Old 10-10-2008, 09:51 AM   #4 (permalink)
NBPRudy's Avatar
Randy
Here's a DIY that might help!
DIY: Changing rear brake pads
NBPRudy is offline   Reply With Quote
Old 10-10-2008, 09:52 AM   #5 (permalink)
Dasllamas's Avatar
Das FA*CREW #152
C-Clamp FTW
Dasllamas is offline   Reply With Quote
Old 10-10-2008, 10:03 AM   #6 (permalink)
so whats crackalakin
St Jude
[hwy]Hagen's Avatar
Hey-gen
there is an attactment that fits in between the lines. as you can see there is like a cross:
to compress this you need
the one with the two indents as shown in the picture are the ones you need to fit in the cross to then compress,
and instead of going straight back like the front wheel, the rear caliper twists like a screw and then compresses.
hope this helps
if you do not have one of these what you do is stick a screwdriver that will fit in the indent and twist it clockwise.
[hwy]Hagen is offline   Reply With Quote
Old 10-10-2008, 11:15 AM   #7 (permalink)
Thanks so much for the awesome help guys!
That explains everything! Thought I was going nuts...
Might as well pick up a caliper compressor, right tool for the jo8.
Thanks again!
Old 10-10-2008, 01:42 PM   #8 (permalink)
St Jude
[hwy]Hagen's Avatar
Hey-gen
yup no problem.
Old 10-12-2008, 09:38 PM   #9 (permalink)
The Power of Dreams's Avatar
My Cool
Just wanted to add one thought. The kit pictured above is probably excessive.
Working on Hondas, the only two brake tools I've ever used can be purchased from O'Reilly Auto Parts.
For screw-type rear caliper pistons:
Lisle 28600
For press-in type front and rear caliper pistons:
Lisle 24300 (mine is actually a little different from that one; it doesn't have a hook on the end, but it works the same)
To facilitate pressing or screwing any piston inside the caliper, I recommend cleaning the boot first so that no debris gets trapped inside the boot when it collapses. If you have the time, there's no reason not to do it. Also, once you clean it, spray silicon spray on it. It will go back in a lot easier than trying to compress it dry.
The Power of Dreams is offline   Reply With Quote
Old 10-13-2008, 12:28 PM   #10 (permalink)
St Jude
[hwy]Hagen's Avatar
Hey-gen
So Blacklespaul did you get your caliper straightened out?
Old 10-13-2008, 12:46 PM   #11 (permalink)
Preston
Hey I work at ford to..
RCracer05 is offline   Reply With Quote
Old 10-13-2008, 12:56 PM   #12 (permalink)
I am Godzilla U R Japan
St Jude
gotsnodooks's Avatar
Russ
Originally Posted by Dasllamas View Post
C-Clamp FTW
NO!!!!! Not on the rear disc!!
You are going to need a special tool which will attach to the piston and turn it while compressing it at the same time. You should be able to go to any auto parts store and rent one.
you are still alive so that fatal error must have fail'd
Never take life seriously. Nobody gets out alive anyway.
gotsnodooks is offline   Reply With Quote
Caliper Talk fiji-blew Suspension and Brakes 9 03-24-2008 08:13 AM
Si Caliper Options smokenrowboy Suspension and Brakes 0 12-06-2007 05:56 PM
Compress a gif Doug Photoshop 2 09-27-2007 09:40 PM
What program do you use to compress DVD's?!?!?! Yo Nadz Technology 25 04-17-2007 09:25 PM
Little Cheapo question on Caliper! mélihonda Suspension and Brakes 7 05-29-2006 10:02 PM
