Old 10-10-2008, 09:18 AM   #1 (permalink)
6 secs of chirping during startup
During startup, as you insert the key and bring it to the "ON" position, there will be 6 chirps ("ting"), at a rate of 1 per second. By the 2nd chirp, the instrument panel would have been "initialized", and if you listen closely to the rear of the car, the fuel pump too would have been ready.
I make it a rule to crank after the full 6 chirps/seconds is up, and during times when I'm impatient (like 2-3 times a year), I crank after the 2nd second.
Am I paranoid? Any technical basis to crank only after the 2nd or 6th second?
(In case anyone's looking at me weird, I'm driving a JDM R18, closest equivalent to the EX).
ivan98 is offline   Reply With Quote
Old 10-10-2008, 09:24 AM   #2 (permalink)
NIGHTHAWKSI's Avatar
Ian
sounds OCD.....lol
Old 10-10-2008, 09:26 AM   #3 (permalink)
buurner's Avatar
Bottles
Honestly, I wouldn't think so. Honda is pretty smart when it comes to electronics it just a startup procedure plus leaving the key in the on position wears out your ignition and starter solenoid.
buurner is offline   Reply With Quote
Old 10-10-2008, 11:33 AM   #4 (permalink)
You're not helping yourself in any way. Once the ECU is active (which is before your starter can turn over your engine) your plugs will fire and your fuel pump starts up. The instrument panel is initialized before your key makes it far enough to activate the starter. Your ECU controls your instrument panel so it's displaying what the ECU tells it to. Your ECU doesn't tell it to update the display everytime it takes a reading from the various systems it monitors. If it did your fuel gague would spike everytime you hit a bump or went up or down a hill because of the pressure and surface level differences. Watch your display closely, all those lights don't turn off at exactly the same time which should tell you that it's not the instrument panel that's initializing, it's the ECU taking the time it needs to accurately read adn average out the information it needs to show you what you want to see on the panel. If it takes 3 seconds for all of the lights to go off and/or stabalize, then it takes your ECU 3 seconds to gather the info it needs and process it for you. It takes a few thousand readings per second and "averages" them to display what it does.
Basically, just get in and start it. You're not helping anything by waiting, but you may be hurting some of your systems.
Itchytoe is offline   Reply With Quote
Old 10-10-2008, 06:08 PM   #5 (permalink)
EagleEyez's Avatar
Andrew
thank you itchy, something i wanted to know but never bothered asking )
EagleEyez is offline   Reply With Quote
Old 10-13-2008, 06:03 AM   #6 (permalink)
Yes, originally I did this - I waited for all the lights to go off/stablize. Off the top of my head, the slowest one is the airbag, at ~ 4-5 seconds. Over time, and esp when I'm not in the driver's seat watching the instruments, I'll just wait for the audio chirps to go off.
Old 10-13-2008, 11:33 AM   #7 (permalink)
I start the car as soon as I insert the key and haven't experienced any issues not waiting for the chirps to stop, so yes just might be paranoid
708CvCSi is offline   Reply With Quote
Old 10-13-2008, 12:08 PM   #8 (permalink)
cdc3rd's Avatar
Carl
Buckle your seat belt before turning on the car, no beeps.
cdc3rd is offline   Reply With Quote
Old 10-13-2008, 01:06 PM   #9 (permalink)
EuphoricRhythm's Avatar
EuphoricRhythm is offline   Reply With Quote
Chirping tires Buddy60540 Mechanical Problems & Technical Chat 100 08-11-2008 09:49 PM
chirping 2nd jda07Si Autocross & Sanctioned Drag Racing 39 09-08-2007 03:29 AM
A question about chirping gears ! ...WillSI07... Civic SI 10 10-24-2006 03:56 PM
200 mph Evo 0-60 in 2.69 secs!!!!!!!!!! webby Garage 7 08-07-2006 03:28 PM
*Vid* Think a Geo Metro can do the 1/4 in 9 secs? Click to see!! Prototype Garage 3 08-11-2005 01:35 PM
