Old 10-08-2008, 01:47 PM   #1 (permalink)
p8ntballer8819's Avatar
Alignment Issue HELP!
Hi fellow 8th gen memebers,
I have a few questions hopefully someone can answere for me, Hear we go;
Well i got into a accident side swiped the rails and hit a curb cant remember how fast i was going. I know I bent a control arm on my passanger side front wheel. So my tires are wearing out on the outer side of the wheel on my driver side and on my Passanger side on the outside. So i have to replace a control arm but i dont have enough money right now. So i was wounder if i take my car to a alignment shop will they be able to work any majic on my car so my tires last me a little longer? And how much do you think itll cost to get this issue fixed.
Thank you guys!!!!
-Oscar
p8ntballer8819 is offline   Reply With Quote
Old 10-08-2008, 07:32 PM   #2 (permalink)
ray
ray's Avatar
I can't really tell you, it's all specific to the actual damage you've incurred. I don't think there's a whole lot of adjustment range on cars these days, though, so other than try to set the toe there's not a lot to do at the alignment shop. And even though this will likely help, this is a dangerous situation that you need properly address. The old 'I don't have the money' thing doesn't change this one bit. Either get the car fixed right, or find some other means of transport--the car's just not safe like that. Sorry you've got the problem, but you're going to have to engineer a real solution.
And you've already mucked up the tires, and risk damaging the CV joints, wheel bearings, suspension, or transmission by continuing to operate the car in its current state. Mess on one or more of these parts and you'll be wishing you could go back in time and fix the original problem--the crash damage--right.
ray is offline   Reply With Quote
Old 10-08-2008, 07:33 PM   #3 (permalink)
ray
ray's Avatar
argh, quoted when I meant to edit. Please delete
Old 10-08-2008, 09:07 PM   #4 (permalink)
Alright thanks. Well right now my tires are Toe in. So the outer tire is wearing out, now can this be fixed by a alignment shop?
Starting Issue /Ignition issue/ - Merged threads cornflake Mechanical Problems & Technical Chat 90 04-17-2009 08:25 PM
Alignment issue tenchi45 Mechanical Problems & Technical Chat 71 10-04-2008 03:40 PM
Alignment issue - DISGUSTED by dealership gtdrifter Dealership Experience 3 06-27-2008 04:58 PM
Alignment issue SiAzul Mechanical Problems & Technical Chat 8 09-12-2007 01:56 PM
Steering or Alignment Issue!!!!!! baddazzcivic Mechanical Problems & Technical Chat 14 12-18-2006 08:28 PM
