#22 (permalink) |
Jeremy
Clutch installs sound quite expensive. If I had to do one, I'd definitely go aftermarket instead of paying the high costs for OEM, especially when I bet the OEM clutch isn't very robust. Just made for the average Joe.
#23 (permalink) |
clutch installs are expensive in a transaxle car because you have to drop the trans. the cost difference isnt really there.
the stock clutchs are designed to engage smoothly, aftermarket ones are designed for power and quick shifts. they generally have few pucks, and they grab abruptly. my advise is, if your burning out an OEM honda (super easy) clutch in less than 100k, dont get an aftermarket. Last edited by e60.deluxe; 10-08-2008 at 04:38 AM. |
#24 (permalink) |
$800 would cover a $300 OEM clutch kit (i.e. clutch disk, pressure plate, release bearing, etc.) and $500 in labor, which is probably pretty easy to achieve. So I think the cost I quoted would not be hard to find for an OEM clutch.
Aftermarket clutches are what they are...you should not assume an aftermarket clutch (or any part) is automatically better. As e60 deluxe pointed out (do you own a 2004+ 5-series?), OEM-style clutches have the following going for them: -Designed for smooth engagement and long life -Utilize an organic material which can afford to be over-heated...when it cools, it regains it's friction characteristics. -When installed properly, it'll feel and operate like stock Aftermarket clutches are often built to handle greater torque loads. They do this, typically, at the expense of some engagement. Now don't get me wrong....there are aftermarket clutches that will improve clutch pedal feel, have great engagement, and provide long life. They typically are....you guessed it....an OEM-style design. They utilize the same clutch design and use an organic material, as opposed to say....a 4 or 6-puck kevlar friction material, which will grab like a mofo and make driving in traffic the worst day of your life. When or if my SI's clutch dies, I might go with an OEM style aftermarket clutch. But I'll do so with the sure knowledge that I am trading the solidity of the stock clutch for the possibility of improved clutch pedal feel/clutch capacity and the potential for unintended consequences. Joe |
#29 (permalink) | |
J.P.
On the way home i was in the process of shifting and all of the sudden the rpms just rise and bounce off the rev limiter ( i had the clutch pedal on the floor because i was shifting) i was so scared my motor was gonna be toast and something seriously wrong i shut it off and pulled over popped open the hood jumped out and checked the motor, belt, oil etc. and when i opened my door again i look down and what do you know my floor matt had slid all the way up kinda of pressing on the gas by it self it probably wouldnt have had enough force to push the gas but i guess my foot was pushing it foward. Well i fixed the floor matt the right way and turned the car on and let out a sigh of relief lol i thought my car was gone but it was ok. Long story short check the floor matt sorry for such a long post lol ![]() ![]()
#30 (permalink) | |
Andrew
| Stock clutch and NITTO NT01 don't mix. I need a clutch!!! | itzwykd | Clutch & Transmission | 52 | 09-14-2010 06:58 PM |
| squeaky clutch on engagement | 8thgencivic12 | Mechanical Problems & Technical Chat | 28 | 10-16-2008 08:18 AM |
| Seattle through the lens of a dying point and shoot | atruhondagrl | Photography | 2 | 08-07-2008 01:11 AM |
| Clutch Engagement | vfmp2012 | Mechanical Problems & Technical Chat | 0 | 06-13-2008 01:09 PM |
| Adjusting Clutch engagement point? (base civic) | Nighthawk R18 | Mechanical Problems & Technical Chat | 11 | 04-13-2007 10:23 PM |
