Old 10-07-2008, 03:23 PM   #1 (permalink)
catchx34's Avatar
car wont start
Here's the problem.
I recently took out the PGM-FI Main Relay 1 located under the hood, to check another vehicle that had a problem with fuel delivery. Long story short, I put the original relay back in and now my car wont start. I dont hear the fuel pump turning on when the key is in the on position and realized that the bars on the temperature gauge goes all the way up and then goes dim as the key is still in the on position.
I tried to switch the main relay with the subrelay located one relay away from it but to no avail. Anyone got any ideas?
catchx34 is offline   Reply With Quote
Old 10-07-2008, 03:24 PM   #2 (permalink)
catchx34's Avatar
hmmm i ordered another main relay per FYI 05 Accord Recall may affect your 06 Civic I tried to scan for trouble codes but it wont communicate with the ecm. I hope this works...
Old 10-08-2008, 10:26 AM   #3 (permalink)
catchx34's Avatar
well.. i changed both relays and it still doesnt start up. I got part #'s 39794-sda-902 and 004.
anyone?
Old 10-08-2008, 12:30 PM   #4 (permalink)
Ryan
Not that this will do anything at all but did you try resetting the ecu by taking the battery connection off.
Fatheadrr is offline   Reply With Quote
Old 10-08-2008, 12:48 PM   #5 (permalink)
Preston
you have a short to ground, or a short to power some where. it put the ecm in a sleep mode so it doesnt get damaged.
RCracer05 is offline   Reply With Quote
Old 10-08-2008, 12:55 PM   #6 (permalink)
arlo03's Avatar
Arlo
arlo03 is offline   Reply With Quote
Old 10-08-2008, 02:23 PM   #7 (permalink)
catchx34's Avatar
ive disconnected the battery for about 30 mins twice yesterday to no avail. I tried to reset the ecm again today with a scan tool but still no communication.
Old 10-08-2008, 02:23 PM   #8 (permalink)
catchx34's Avatar
how do u put it in sleep mode? Isnt there a fuse or relay inside the ecm to prevent it from blowing up?
Old 10-08-2008, 11:22 PM   #9 (permalink)
catchx34's Avatar
Hmm... Does anyone in Md have an HDS i can borrow to reset the ecm?
where to start? tranceFusion I.C.E., Electrical, Security, & Navigation 3 06-19-2008 02:27 PM
When should I start?? civicblack33 Introduction & Pictures 6 01-21-2008 04:56 AM
Where to Start? d-hardt20 Bolt-Ons And All-Motor 5 01-08-2008 06:06 AM
Where to start? zenith931 Autocross & Sanctioned Drag Racing 8 06-10-2007 07:05 PM
Si wont start Yankees8924 Mechanical Problems & Technical Chat 11 03-30-2007 01:16 AM
