Synthetic Manual Synchromesh Transmission Fluid Facts/Opinions
Hey guys,
I have an 08 FA5 with 4500 miles on it. The weather has gotten colder lately and I noticed an increase in the transmission's notchiness even in normal driving conditions. I do get the occasional grind into second and third, but nothing significant. In fact, it's usually light enough for the passenger to not even hear it. I am fortunate to not have the 3rd gear pop out issue, "knock on wood", however I can tell going into 2nd and 3rd doesn't feel and sound as smooth as the other gears.So I am deciding to switch to the Amsoil Syncromesh 5w-30 MTF. I've read over a dozen threads and heard many good things about it. However I want to start a thread where everyone's opinion/facts can be viewed without a hard search. Therefore, can you post your Car: (Si, Ex....etc) Year: Mileage before MTF swap: Current Mileage: Comments: (The good, the bad, warranty issues, price/quart, recommendations) Last edited by jaxson; 10-07-2008 at 01:56 PM. |
Hidy Ho Neighbor
Car: Si
Year: '07 Mileage before MTF swap: approx. 20,000 Current Mileage: almost 30,000 Comments: No issues whatsoever. Greatly improved shifting. Had a local shop do the work (they had a lift, and I'm lazy). Bought online, and don't remember how much it was -- you only need 2 quarts though.
Car: SI
Year: 06 Mileage before MTF swap: 15000 Current Mileage: 52000 Comments: AMSOIL MTF, I have never once experienced a 3rd gear pop-out or lock-out since I switched 37,000 miles and 2 winters ago. Shifting effort greatly improved. At 37,000 miles, I feel some slight notchiness returning and will swap some new AMSOIL MTF fluid in. I bought a 6-month AMSOIL membership, which gives you wholesale pricing. I bought 2 quarts of MTF and 4 gallons (16 quarts) of AMSOIL SSO 0w30 at the same time, which saved me about $50 over buying all that at retail pricing. |
Car: SI FA5
Year: 07 Mileage before MTF swap: 20K+ Current Mileage: 35K Comments: Before i got my 3rd recall fixed i swapped to the new Honda MTF and for over 2mons all my symptoms with the 3rd gear were gone. I then swapped to Amsoil MTF and didn't notice any real difference. I also change the fluid every 5K miles or so with the engine oil. I'm trying to decide weather from this point forward if i should go with Amsoil or Redline MTF. |
Car: Si
Year: 06 Mileage before MTF swap:9k Current Mileage:21k Comments: Used Amsoil which completely fixed third gear issue and removed most of the notchyness. One thing I noticed is the tranny feels smother in colder weather. Very happy with Amsoil highly recommend it. Last edited by slimfit; 10-07-2008 at 04:11 PM. |
Firm approval....I haz it
Car: Si FG2
Year: 06 Mileage before MTF swap: 10K or slightly less Current Mileage: 39,8XX Comments: Noticed some notchyness coming back since it is time to change the fluid. Will be changing to Amsoil again very very soon.
#12 (permalink) |
Jaxson - For me, it solved the problem (see my post). My car had, multiple times in the winter of 06/07, been locked out of 3rd gear or popped out of 3rd gear. It would occasionally lightly grind 2nd or 3rd. It has been 37,000 miles now....and not a single 3rd gear people has occured since (i've occasionally had very, very heavy notchiness in 2nd when cold, but no real grinds).
Bear in mind that when you drain and put in new fluid, you are not really getting all the old fluid out. So refreshing the AMSOIL fluid should actually provide a better feel than occured during the first fluid swap...as you get more of the original out, and the worn AMSOIL. Joe |
#13 (permalink) |
Thanks for your insight Joe. Im just not sure if its necessary for my 08 Si, which is why I hope this thread can help me and possibly other's determine. I bought mine in May 08 and it supposedly got honda's updated MTF according to my .....7075 VIN, which prob explained why I havent gotten any 3rd gear pop out or resistance that most ppl have mentioned. I just have notchiness going into second and I hear a metal on metal sound, like "chhweeekkk," going into 3rd. I dont think it's necessarily a grind, but it def sounds diff than the other gears going in. It's esp noticeable in the cold mornings, but then again I heard this is an issue with most front wheel drive cars. I just dont know what's normal and what's not.
Anyone have specs on the new honda mtf....? Last edited by jaxson; 10-08-2008 at 08:47 AM. |
#14 (permalink) | |
#15 (permalink) |
I had the notchyness with the stock fluid then I changed it to the Amsoil and the notchyness went away. It is coming back now due to the fact that the fluid is "worn/old" (if you wanna call it that) Amsoild says to change every 30K.
I have always had the noise that you get going into 2nd and somtimes 3rd. Ive only had the 3rd pop-out 3 or 4 times of owning the car. Anyone know how long it takes to get the fluid shipped to your place with reg. shipping? I cant remember. Anyone buy the fluid from a local store?
#16 (permalink) |
I guess my concern is should I risk giving Honda an excuse to reject any possible future transmission warranty problems, to fix somethign that is not broken, atleast as of now. Or should i just change my mtf and prevent any future damage. Eeverytime we feel notchiness or hear a clunk, that's somethign wearing right?
#17 (permalink) |
AMSOIL MTF is not something a local AMSOIL dealer will USUALLY stock (told to me by my local dealer). If I may recommend a course of action....if you want to enjoy the AMSOIL experience, get a $10 6-month AMSOIL preferred customer membership. Then buy 2 quarts of AMSOIL MTF and ~4 gallons of AMSOIL SSO 0w30. Then run your oil changes for a minimum of 10,000 miles (10,000 on SSO is a piece of cake if you do moderate driving...i.e. 15,000 miles a year and mostly driving with the engine warmed up plenty).
Jaxson - Is that you in your picture? You look familiar. I live in West Chester and work near Willow Grove. If you are nearby, you are welcome to drive my 06 SI with 52,000 miles and mostly worn out AMSOIL MTF ![]() Joe |
#18 (permalink) | |
#20 (permalink) | |
10K to 39k no notchyness due to using Amsoil(feel like butter, lol) At 39K started feeling notchyness due to Amsoil needing replacement. Hope the helps.
| DIY: Changing Manual Transmission Fluid | BATANG CITY JAIL | Transmission | 523 | 06-15-2009 06:16 PM |
| Synthetic Manual Transmission fluid | GARCIA8519 | Ontario | 42 | 10-13-2008 02:11 PM |
| Need to change my manual transmission fluid to that syncro from royal purple | 1.8L FG KiDd | Civic Coupe And Sedan | 2 | 03-22-2007 12:44 PM |
| Manual Transmission Fluid | FusionSi11 | Mechanical Problems & Technical Chat | 40 | 01-18-2007 02:14 PM |
| Changing to Synthetic Tranny Fluid | 06workhorse | Do It Yourself Articles | 7 | 05-14-2006 11:41 AM |
