Old 10-07-2008, 01:17 PM   #1 (permalink)
ro.sniper's Avatar
Razvan
Engine whine on R18 after filter re-oiling
Like the title says. I changed my oil 3rd change now. I also decided to clean my KN drop in filter. I cleaned with the solution, rinsed, waited a couple of hours so it was dry and re oiled. I realized that i started spraying oil on the clean side instead of the former dirty side, waited 20 mins and put the filter back in. Now my engine makes a funny whining noise as if it whistling , it gets loud at around 2.5k rmps and up... Do you think I put too much oil? Should I re-clean and oil on proper side? Its damn annoying!
ro.sniper is offline   Reply With Quote
Old 10-07-2008, 01:36 PM   #2 (permalink)
if it's whistling, maybe you didn't assemble the airbox correctly and air is leaking "past" the filter's seal?...go back and make sure the box is all buttoned up correctly
708CvCSi is offline   Reply With Quote
Old 10-07-2008, 01:44 PM   #3 (permalink)
asndragonboii's Avatar
If you put the oil on the wrong side, and you knew it, why the heck did you install it? If you read the directions, it says if you accidently put oil on the wrong side, clean it and start over.
Like the other guy said, make sure you clipped all the clips and check for air leaks.
Old 10-07-2008, 03:43 PM   #4 (permalink)
ro.sniper's Avatar
Razvan
^ BALLS across the chin, you are right but it was damn late and work at 6 in the morning, that was really stupid of me....
Old 10-07-2008, 10:16 PM   #5 (permalink)
The first time i cleaned/oiled it, I took my sweet time because i didnt wanna mess up. If youre doing something for the first time, just make sure you have plenty of time so you arent in a rush and mess things up
Old 10-07-2008, 11:59 PM   #6 (permalink)
ro.sniper's Avatar
Razvan
Yup i'm oiling it again right now, dirty side only, and it was re-cleaned. I hope this time it will be done 100% perfect.
Old 10-08-2008, 12:25 AM   #7 (permalink)
I'm a bit confused about something...I've been using K&N fiflters for several years on the past several cars I've owned, currently have one in my GTI(going on 5 yrs with it) and when I opened the package the filter comes oiled from the factory and guess what? the entire filter element was oily on both sides since the cotton gauze just absorbs all of the oil...having said that what difference does it make what side gets oil? once you spray the oil all of it gets absorb throughout the whole element anyway, the 2 occasions I've sprayed mine I did the "filtering" side and it didn't matter since once the oil was absorbed, it looked like I had oil the entire filter and that's with me being conservative with the oil...you guys obviously haven't seen how you oil the circular(donut) filters, you dunk the whole thing in oil...just as long as you don't over do it you should be fine
Old 10-08-2008, 08:34 AM   #8 (permalink)
ro.sniper's Avatar
Razvan
Update: I put the freshly re-oiled filter in, and it still whistled for a few km while driving and then it stopped.... I'm stumped... if it doesn't happen anymore I will be extremely happy. If it does i'll reset the ECU as my next step. If that doesn't work I'm going to the dealership with my paper filter in and ask them to take a look at the car.
Old 10-08-2008, 08:50 PM   #9 (permalink)
ro.sniper's Avatar
Razvan
Update: whining/whistling is now gone after proper re-oiling. It has not occured again after sever starts/stops.
Whine after changing engine oil and MTF user Mechanical Problems & Technical Chat 13 12-15-2008 02:21 PM
Is engine whine normal on the R18? rationull Mechanical Problems & Technical Chat 13 10-07-2008 10:02 PM
Low Throttle Engine Whine gangreen84 Mechanical Problems & Technical Chat 10 05-15-2008 01:02 AM
Engine whine with AUX/iPod Kid Red I.C.E., Electrical, Security, & Navigation 23 07-31-2007 07:58 PM
Engine Whine. Hondalways Civic Coupe And Sedan 25 05-18-2006 08:42 PM
