Old 07-25-2006, 11:30 PM   #1 (permalink)
Unhappy Three irritating problems
Hello all. First time poster. I just had my DX-G in for it's first check up, and asked them to deal with a few problems. They corrected none of them. Here they are in no particular order:
1. Poor FM reception. I get a rapidly repeating ticking/thumping noise in the background whenever I tune to an FM station. They say they've had similar complaints, but don't know how to fix it.
2. Clicking noise coming from the accelerator pedal. Unless I'm extra smooth with the pressure, I get the noise every time I press it or let off on the pedal. They claimed they couldn't hear it.
3. Poor door alignment. The passenger side rear door looks like it's ajar, even when it's closed tightly. Again, they claim they adjusted the passenger front door, but didn't see anything wrong with the others.
I know I'm being picky, but I truly believe in Honda's quality, and I don't think I should have to settle. Anyone else having any of these problems?
Thanks and I'm glad to be aboard!
uechiman is offline   Reply With Quote
Old 07-26-2006, 12:04 AM   #2 (permalink)
n00b retro whore
ethlar's Avatar
first off, welcome to 8thcivic
on to buisness
fm quality is going to suffer cause you have an in window antenna instead of a seperate mast. as for the accelerator clicking mine makes a clicking noise too, i just turn up the music. i got nothing on the door though, somimes my drivers door doesnt want to close but thats it
Old 07-26-2006, 12:08 AM   #3 (permalink)
Acorns!
webby's Avatar
welcome to the site. I'm not sure where you're located, but if you've got another dealership in your area - I'd stop in.
Bring up the issues you have with your door etc, and see what they can do for you. One dealership might be a lot better for you than another. You can take your car for service anywhere in the US - not just where you bought it.
webby is offline   Reply With Quote
Old 07-26-2006, 12:12 AM   #4 (permalink)
I agree I'm going to have to try another dealership. It's a shame, because the one I brought it to is supposed to be "award-winning". I've had other cars with built-in antennaes in the windshield, and this is the first time I've experienced this reception problem. I was hoping it was just a loose connection of some kind. As for the gas pedal, I don't understand why they couldn't just tighten up the pivot point or make some kind of adjustment. It's the old curse though...they never seem to hear the same weird sounds at the dealership that the customer does when driving.
Old 07-26-2006, 01:12 AM   #5 (permalink)
Tiznonay's Avatar
Ive never had any of those problems... but If i did, I wouldnt settle for it either. And for the record, what exactly is a DX-G? I keep seeing that, is that just like a DX?
Tiznonay is offline   Reply With Quote
Old 07-26-2006, 01:41 AM   #6 (permalink)
06CivEXJon's Avatar
Jon
Is your car a sedan?
Old 07-26-2006, 09:34 AM   #7 (permalink)
Yes, it's a sedan. A DX-G is basically a souped up DX..comes with a bunch of goodies the DX doesn't.
Old 07-26-2006, 09:43 AM   #8 (permalink)
Resident Caraholic
Cybergypsy's Avatar
Mine so far has no Issues, my radio is fine, maybe because I have navi....Take it to a dealer in your area, someone will fix it...
Dreams have only one owner at a time. That's why dreamers are lonely.
Erma Bombeck
Old 07-26-2006, 12:33 PM   #9 (permalink)
I've picked-up my EX sedan 2 weeks ago (after a 5 week wait). I experienced 1 and 3.
The FM reception was poor for one station while driving by a cell tower (my radar detector always beeps by that area also). But only occured a few times, then it 'fixed itself' and went away.
The driver's door was also sticking out ~3mm when closed. They adjusted it and now it's good.
As for the accelrator pedal, there was a recall (or TSB). Probably dealer checked and I'm sure they said it's not affected.
SuperCivic is offline   Reply With Quote
Old 07-27-2006, 10:20 AM   #10 (permalink)
There was/is a recall for the accelerator pedal. The problem was physical...some early build cars did not have the pedal secured properly at the floor.
targettuning is offline   Reply With Quote
Old 07-27-2006, 07:00 PM   #11 (permalink)
PokeyD16Z's Avatar
the passenger door seems to be designed to stick further out than the driver's side. Seen it already on quite a few sedans...I thought it was a problem with mine at first.
Old 07-29-2006, 01:07 AM   #12 (permalink)
TreeFrog's Avatar
both my doors stick out from the front fenders on my si. i wonder if i should ask the dealership about it
TreeFrog is offline   Reply With Quote
Old 08-08-2007, 01:50 PM   #13 (permalink)
Mateen's Avatar
Is this true?
I just noticed that the passenger door on my coupe is not flushed on top part with the body (sticks out about 1/4 Inch).
Do I need a door adjustment or should I just let it go?
Mateen is offline   Reply With Quote
Old 08-10-2007, 02:28 AM   #14 (permalink)
Mateen's Avatar
Old 08-10-2007, 03:29 AM   #15 (permalink)
GenghisKon's Avatar
Kon
Did you get your windows tinted? Ceramic tint I know interferes with Navi so it might interfere with radio too. The Gas pedal just needs to be adjusted / tightened and it wont make that noise. The door issue I don't know I haven't noticed that problem
GenghisKon is offline   Reply With Quote
Old 08-10-2007, 04:02 AM   #16 (permalink)
i have a problem with my passenger door not lining up flush with the front fender, the stealership called this a saftey feature, "leading edge technology," is what they called it. they say it helps prevent the door from being un-openable in the event of a collision. funny thing tho, i guess they dont give a $hit about the driver because the driver side ligns up perfect. genghiskon, as far as the tint goes, i see no difference in the navi system with ceramic tint, just as $itty now as it was before, absolutely no change. i had a 2000 ex that had ABSOLUTELY NO problems, this 8th gen is full of them
catfish80 is offline   Reply With Quote
Problems cazzerz Civic Coupe And Sedan 12 10-18-2006 02:07 AM
Problems with the Civic Sedan?? psylenc2k Civic Coupe And Sedan 42 06-13-2006 09:55 AM
A few problems in less than a month ToBeHuman Mechanical Problems & Technical Chat 4 05-23-2006 01:47 AM
PROBLEMS with XD6000K Kit CANMAN Lighting, H.I.D.'s, & Neon 8 05-02-2006 08:44 PM
Anyone have problems with the headrest? iVTEC Mechanical Problems & Technical Chat 9 05-01-2006 01:33 PM
